Hi everyone,
My name is Ricardo, and I inform you right away that I do not have any experience with coding or arduino boards or others .... I am a beginner ...
Since I'm a bit curious, and the basketball club where my young son plays needs an electronic scoreboard, I thought make one ... maybe i am a little crazy ...
So what I want is an electronic scoreboard that counts the score of the teams and controls the playing time, mark the faults and the periodos of the game.
Measurements of the board
85 cm X 65 cm powered by transformer or batteries 12v.
Measurements of digits (points and time)
7 segments with 5 cm per segment ( 3 leds itch strip )
** Point counter (independent for each team)**
The points counter will consist of 3 digits for each team, starting at 000 and finishing at 199.
The counter must be operated by buttons, always adding only one value at a time, up and down score and reset to go back to 000.
Time counter
The timer (stopwatch) should be 4 digits ( 13:52 ) and should work in countdown.
It should also have the following options (using the buttons):
Reset resetting zeros
Control by the user of the time that is decided (the time is not fixed), it can star at 12:00, 08:00, 10:00 etc. always in minuts and seconds. If possible when the time reaches 00:59 ( zero min and 59 sec ) starts counting in seconds and milliseconds.
When the countdown is running, you can stop time and then continue the same sequence.
When it reaches the zero (00:00) it activates a buzz ( loud enough of 3 seconds )
Faults
The faults swould be light in the score board ( 5 fault for each team ), and swould have a ball possession indicator (arrows next to the stopwatch)
I hope you have put all the necessary information and that can help me.
Again, I do not understand nothing of the subject , but with some research and help by some good people that I contacted, I already performed a draft of the board.
Finally, I wonder if it is possible to do this project with a console to control the scoreboard by RF or WIRELESS?
I already have:
5 mt red 12v led strips ![]()
I intend to use Arduino board (if it is easier)
In attachment:
Idea of the scoreboard ( foto )
Schematic attempt for stopwatch ( Drawing of electric scheme and fritzing file )
(The buzzer, start button, pause button and reset is missing and some connections should not be fine ....)
Sorry for the english, but I'm using a translator to be faster
Thank you all
Ricardo Alexandre
