Battaery connector on nano mkr 1010 WiFi
I ordered some LiPo batteries to power my Arduino nano mkr 1010 WiFi project.
The batteries got a wrong connector,
Does anyone know the name / size of the battery connector on the arduino. Maybe someone even knows a good source where I can buy these?
Thank you
The part number of the actual connector on the board is marked "S2B-PH-SM4-TB" on the MKR1000 schematic (unmarked on the schematics for other MKR boards). The "S2" means side entry, 2 pin. The "SM4" means surface mount, which is not relevant to anyone looking to figure out which connector mates to it. My research indicates that all you need to know it it's a JST PH 2 conductor connector. All the PH series connectors are intercompatible regardless of the minor variations. You can find a lot of them on eBay with a search for "JST PH".
Ideally, all you would need to know is it's a 2 contact JST PH connector. All JST PH connectors are compatible with each other. Unfortunately, a lot of people (e.g., eBay, Aliexpress) are selling what they call a "JST PH 1.25", which has a 1.25 mm pin pitch. But all the JST PH have 2 mm pin pitch, so I don't know what that is. Maybe the JST GH? So you need to make sure the JST PH connectors you get from places like eBay specify they have a 2 mm pin pitch.
Datasheet for the JST PH series connectors:
ah, thank you. very detailed and useful answer
You're welcome. I'm glad if I was able to be of assistance. Enjoy!
Per
