Hi, I am looking for some li-ion battery online. There are 4 pack -4 AA size batteries a pack. The seller state s
3.6 volt 3400mAH. Does it mean 3.6V for each battery or does it mean 3.6V for the pack (All 4 batteries?)
TIA
TIA
Single Cell LiPo Batteries are 3.7V. If they are 4 used or assembled in parallel, its still 3.7V. Since they say nothing about 14V... they must be parallel. If is VERY unlikely that a single AA size is 3400maH.
If packed in series, you need a balance cable attached as well, if they are remain in series while being charged. 4 batteries in series would be 4 x 3.7V... 14.8 V or so.
Best guess, is that it is 4 parallel batteries for more current capacity, hence the high 3400mAh rating.
can you post the link of the mentioned product? by AA size you mean 14500 battery pack?
Usually a single 14500 battery comes in min 600mA to max 1200mAh per cell. So if the product is described 3400mAh, it will be most likely parallel pack(3400/4 = 850mA per cell) sounds genuine to me.
and they are not really AA sized
