BEFORE you 'make' something... DC circuits
OK - as the OP, I felt I should contribute part of the solution...
Most issues in hardware arise because newbies have NO IDEA how the pieces fit together...
It's nothing like putting batteries into a LEGO Mindstorm kit.
The software will NEVER operate correctly if you have made incorrect assumptions about 'what plugs where', and 'why'
Software development is a complex process, and is no easier if the goal posts are moving!
Most professional organisations have separate or overlapping specialists to handle the functions - you've just signed up without any experience to do both! So forgive some terse replies, and expect to do some of the thinking for yourself. (Not directed at anyone!)
kolleamm:
Nobody has the time to read all the fine print of every site.
While that is true it is also generally unnecessary.
Very many questions are asked here that would have been answered if the person had did a Google search and read the first or second link that Google throws up.
When people take the trouble to do a little research they can learn enough to ask a more focused question.
And spending an hour or two reading this Forum before asking a first question will give the person a good idea of how the Forum is actually used and what is the most effective way to get information.
When I see questions titled "Help" I wonder how the person could be capable of writing a computer program if they don't even apply enough logic to understand that every single person is looking for help. Similar thoughts go with poor spelling and punctuation - because a compiler is utterly unforgiving.
...R
holmes4:
Whats more if you think of a transistor as a pipe (garden hose) with your foot on the hose. Move your foot half an inch closing the pipe completely - no jet of water. Take your foot off -a 20 foot jet of water!
And that's a digital (on/off switch). Keep your foot on the pipe and move it with in that half inch and you have an amplifier. And's really all you need to understand in order to use a transistor!
Mark
The water flow/electricity analogy has been de rigueur in teaching elementary physics since ... ever. I like it, and everyone uses it. I have, however, seen problems happen, especially where the kinetics are not a continuous function (such as batteries) are involved, so the model does not apply.
"SPDT (look it up)"
"over-voltage...and too much current ( yes they're different)"
LOL...
I think you've missed the whole point.
Many people buy arduinos so they DON'T HAVE TO LEARN ANYTHING !
This is the reason for almost half of all newbie posts.
They don't want to learn electronics because they think the arduino is the ticket to SKIP ELECTRONICS. ( of course they're wrong but they somehow start out with that misconception.)
I wouldn't be surprised if more than 50% of ALL newbies have NEVER soldered.
What does that tell you ?
Is it really not possible to be interested in electronics WITHOUT arduino ?
WHY does the arduino signal their FIRST exposure to electronics ?
Why didn't they start with TTL , BCD to 7-segment decoders, CMOS and 555s like the rest of us ?
When I took the Heathkit Home Study Electronics courses I had to go through DC, AC SEMICONDUCTOR DEVICES and ELECTRONIC CIRCUITS BEFORE I could do the MICROPROCESSORS course.
Now they buy the microprocessor and ask what a capacitor is or what the resistance of a LED is. What's wrong with this picture ?
ChrisTenone:
There exist kinetic analogies as well (hydraulic ram - switched solenoid), but these are hard to understand in either model.
Many people will be happy to know the difference between voltage and current, before they try to stick their brand new multimeter into a wall socket, for a first test. Others wonder why their sensor doesn't work without a common ground connection. Such basics IMO should be explained in easily comprehensible analogies, before presenting electric formulas for the rest of a tutorial.
Another teacher tried to explain a programming language to an uneducated audience, by an in-depth presentation of its syntactic grammar. No wonder why nobody could provide a single line of code to the exercises.
Finally a tutorial is not a PhD thesis, whose audience will expect and understand mathematical formulas and proofs. Engineers and makers do not require a complete theoretical background, instead they want to know how to use electronic components and the capabilities of a programming language. Often a rule of thumb is more useful than an exact formula, in many practical situations (resistor values for pullups or LEDs...).
raschemmel:
Right, such people confuse electronic components and modules with Lego bricks, which can be combined at will, and will work as soon as their buildup looks good. Unfortunately both electric current and software are almost invisible, but both are required as well, to make a microcontroller project work.
raschemmel:
"SPDT (look it up)"
LOL...
Althought I think there should be a test on HOW to post to this forum, forcing someone to make a test post. graduates have subject lines that are not capitols, do not contain help or newbie and have to post at least 2 sections with code tags..... AND attatch a schematic.
I think the whole reason for this forum is so that you can share what you learned, and as anyone who ever surfed for hours only to find they did not use the correct search terms, get pointers on WHERE to find the answers.
what I find annoying is when a poster asks for a very specific thing and responses advise the exact opposite. Someone has a tag line that they asked how to power an LED, were asked what color, and then told to buy a flash light.
lastchancename:
IMHO the mixed bag of Replies that you have received (all of which are competent) shows very clearly why you need to take charge of the content of your tutorial (assuming you wish to write one). :slight_smile:
Also IMHO a newcomer needs a simple and clear learning path without digressions. And simplicity is probably better than fully extensive technical accuracy.
...R
I think newbies make all electronics hobbyists better off because they help create a market.. I doubt the teensy would exist if there were only a handful of old farts still playing with there ham radios.
Letting the smoke out supports the hobbyist market.
Of course that's true , but that being said, who are the newbies going to when they don't know up from down ? (the old farts)
Well, as long as the newbies don't mind the air
(goes back to see what started this) You mean like this? https://www.arduino.cc/en/Tutorial/Foundations :slight_smile:
Before you know it, the fly by night paper mills will be flogging an Ard++ certification for people to put on their resumes. :slight_smile:
No shxt kidding ? You mean I can put all my arduino projects on my resume ? Should I add the ATtiny85 experience or the ATmega328 DIP with OPTIBOOT BOOTLOADER standalone projects or my programming board.?
Hey, that reminds me, I just did voltage monitoring op amp circuit a while ago...I better add that...
aarg:
I'm seeing a whole new community college program here!
Qdeathstar:
I agree, there are so many of us old farts around these days we could start any electronic trend.
"I have a double garage, I'm gunna make a valve/tube version of a trash80."
lol.. Tom.. :slight_smile:
I got a brand new Pertec PCC-2000 CPM computer ($12,000 new) for $100. It was msde for Eurooe znd some idiot here in the USA fond it still in ghe shipping box and decided to test it here , not realizing the Specification plate szid *0 Hz , not 60 Hz. Of course it blew thd power supply power transistors. My lead tech at work was older and had more connections. His friend told him his company told him to get rid of it. He brought it to work and sold it to me. All I had to do was fix the P.S.and get the CPM OS . I fixed it and filed the 8" floppy fisk drive pullys to 5/6 of oiiginal diameter so the 50 hz motors would rotate at the right speed. I had go join the CPM club to get the Modem,-7 software to get onto thr BBSs before the internet.
Have you been out late again?
Robin2:
Amen to that.
TomGeorge:
Hi,I agree, there are so many of us old farts around these days we could start any electronic trend.
That'll be a LOT of valves!
