Hey im trying to execute this program which is supposed to take values from a bluetooth module via a smartphone and use those values to turn on and off a buzzer.
I used the following code:
char data= Serial.read();
if(data= 'a')
tone(8,1550, 300);
delay(600);
else if (data= 'b')
tone(8,0,300);
delay(600);
But it keeps giving me the error 'expected unqualified id before 'if' '.
Please help.
I want the buzzer to sound once you press a on the smartphones app, and continue sounding until b is pressed.
Okay so. A bit improvement.
int dd= 1;
if(Serial.available()>0)
switch(data)
case 'a': dd=2;; break;
case 'b': dd=1; break;
do
tone(8,1550, 300);
delay(600);
} while (dd=2);
Now if I press 2, the buzzer doesnt stop sounding. I want it to to stop making that sound when I press 1.
Its not happening.
Helppp.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
In your first code;
if(data= 'a')
tone(8,1550, 300);
delay(600);
What is
if(data= 'a')
Doing between the void setup() and void loop() ?
Tom.. ![:slight_smile: :slight_smile:](https://emoji.discourse-cdn.com/twitter/slight_smile.png?v=12)
Be sure to understand the difference between = and ==
To elaborate on ChrisTenone's post:
"=" assigns a new value to a variable
as in: make my variable called x store the number 6:
x = 6;
"==" means is equal to
as in: if the number stored in the variable x is equal to 6 then do something
if (x == 6) {
//Do something
Have a look at the reference pages on:
- Equal to (=)
- the Assignment operator (==)
