Hello, I am trying to build an ihome, and I am having issues when it comes to finding the correct resistance to use. I am trying to charge the ipod touch 3g using the data+ and - connections. here is a quote from the table:
To charge an iPhone 3G / iPod Touch 2nd gen, usb data- (25) should be at 2.8v, usb data+(27) should be at 2.0v. This can be done with a few simple resistors: 33k to +5v (23) and 22k to gnd(16) to obtain 2v and 33k to +5v and 47k to gnd to obtain 2.8v. This is a notification to the iphone that it is connected to the external charger and may drain amps from the usb.
I am not understanding why I would need resistors at ground AND the power source, and I am having trouble understanding how all of this will be connected. Here is a quote that simplified the hooblah in the first quote:
Has anyone used one of these to charge an iPod Nano (6th gen)? Based on reference material for the MintyBoost, I was thinking 5V at pin 23, Ground at 16, then 2.8V (2.7, in my case, and in the case of my 10W Apple wall charger) on pin 25, and 2.0V on pin 27. When I attach the iPod, the voltage at pin 27 drops to 0V (0.01V). Thinking maybe the MintyBoost information was just wrong, I sacrificed a USB cable, plugged it into the Apple charger, measured the voltages, and confirmed what I was producing. From there, I ran the Apple charger voltage through the PodGizmo via my sacrificed USB cable, and get the same behavior. Can the traces on the breakout not provide the current needed to charge, or could my breakout be faulty? (Hope it’s not the faulty one, because I desoldered the connector, and was soldering wires to the pins when I broke off a pin and trashed it - I’d just like to know if I should bother ordering another one of these…). My project kind of depends on being able to charge the device…
Here is a picture of the podBreakout, I have a 3.3 volt connection using a logic converter if it would be easier to bump down the voltage from there, otherwise I have a 5v power source from an UNO r3:
So my main question is, how am I supposed to connect all of this so it charges the ipod, and how can I do it in an efficient way?
