I am having trouble getting my program to wait for a key board input.
Task is to use the arduino uno to output a PWM waveform to some hardware and to wait whilst I make some measurements. I then plan to send a serial byte (any byte) to get it to move on, increase the PWM value by an predefined increment and repeat until the max value of 255 is reached.
the first wait loop WAIT1 is working and I can start the program, wait until I enter the stepsize but it gets stuck in the WAIT2 loop.
Please can anyone point me to why my code does not work please.
TIA
When I enter stepsze2, my serial window shows:
Enter step size 1-9 Step size =2
value is 0
My code is
int val=0;
int stepsize=1;
int dummy=0;
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
Serial.print ("Enter step size 1-9 ");
WAIT1:
if (Serial.available()==0) {
goto WAIT1;//wait for key press
stepsize=Serial.read()-48;//convert from ASCII to number
Serial.print("Step size =");
Serial.println(stepsize,DEC);
Serial.print ("value is ");
Serial.println(val,DEC);
NEXT:
analogWrite(9,val);
Serial.flush();// might not be needed?
WAIT2:
goto WAIT2; //wait for key press <<<CODE GETS STUCK HERE
dummy=Serial.read();// used to read the input buffer but I don't use the data
val=val+stepsize;
if (val<=255) {
goto NEXT;
