Hi!
Im farely new to Arduino, ive been reading up, but cant make out whats actually works and what dose not. Right now I am looking for a code for rotory encoders to include in my bottun box build.
Here is the catch! I want to be able to turn the rotory encoder fast whitout it skipping or bouncing.
Here is some code that according to a youtube video that seem good to me. However its to complicated for me to understand fully as of now.
My questions:
- Am I going to be able to use this code, and somehow expand it so it covers 3 diffrent rotory encoders?
- Can this code be included in a button box build with a ghosted button matrix, and 2 potensimeters?
- If i have to much code will the buttonbox "lagg"? or is this code "better"
Marco Pinteric is the brain behind this, and it is being shown in a youtube video by Ralph S Bacon. (i dont know if i can post videos)
#include <Arduino.h>
// Rotary encoder pins
#define PIN_A 32
#define PIN_B 4
#define PUSH_BTN 16
// A turn counter for the rotary encoder (negative = anti-clockwise)
int rotationCounter = 200;
// Flag from interrupt routine (moved=true)
volatile bool rotaryEncoder = false;
// Interrupt routine just sets a flag when rotation is detected
void IRAM_ATTR rotary()
rotaryEncoder = true;
// Rotary encoder has moved (interrupt tells us) but what happened?
// See https://www.pinteric.com/rotary.html
int8_t checkRotaryEncoder()
// Reset the flag that brought us here (from ISR)
static uint8_t lrmem = 3;
static int lrsum = 0;
static int8_t TRANS[] = {0, -1, 1, 14, 1, 0, 14, -1, -1, 14, 0, 1, 14, 1, -1, 0};
// Read BOTH pin states to deterimine validity of rotation (ie not just switch bounce)
int8_t l = digitalRead(PIN_A);
int8_t r = digitalRead(PIN_B);
// Move previous value 2 bits to the left and add in our new values
lrmem = ((lrmem & 0x03) << 2) + 2 * l + r;
// Convert the bit pattern to a movement indicator (14 = impossible, ie switch bounce)
lrsum += TRANS[lrmem];
/* encoder not in the neutral (detent) state */
if (lrsum % 4 != 0)
return 0;
/* encoder in the neutral state - clockwise rotation*/
if (lrsum == 4)
lrsum = 0;
return 1;
/* encoder in the neutral state - anti-clockwise rotation*/
if (lrsum == -4)
lrsum = 0;
return -1;
// An impossible rotation has been detected - ignore the movement
lrsum = 0;
return 0;
// The module already has pullup resistors on board
pinMode(PIN_A, INPUT);
pinMode(PIN_B, INPUT);
// But not for the push switch
pinMode(PUSH_BTN, INPUT_PULLUP);
// We need to monitor both pins, rising and falling for all states
attachInterrupt(digitalPinToInterrupt(PIN_A), rotary, CHANGE);
attachInterrupt(digitalPinToInterrupt(PIN_B), rotary, CHANGE);
Serial.println("Setup completed");
// Has rotary encoder moved?
if (rotaryEncoder)
// Get the movement (if valid)
int8_t rotationValue = checkRotaryEncoder();
// If valid movement, do something
if (rotationValue != 0)
rotationCounter += rotationValue * 5;
Serial.print(rotationValue < 1 ? "L" : "R");
Serial.println(rotationCounter);
if (digitalRead(PUSH_BTN) == LOW)
rotationCounter = 0;
Serial.print("X");
// Wait until button released (demo only! Blocking call!)
while (digitalRead(PUSH_BTN) == LOW)
delay(100);
