Hey guys,
This topic is probably old but I need advice for a diode to provide a reverse polarity protection in my Low-power circuit. I'm using ESP32 and would like to minimize the consumption.
I was told Schottky diodes 1N5817, BAT54 or MBR0530 could be good choices. Or maybe a diode with a low-threshold voltage like the BAT54A-7-F.
What do you think?
Thanks
Thanks for your answer. Yeah, probably nothing indeed.
I'm aware of these and wanted to make it simple for now.
So are the references I wrote good you think?
Current rating is important in your application. Be sure to get one rated for more current than your circuit requires.
The maximum current is about 100-150mA
Consider the form factor that you can solder.
The 1N5817 is a good trade off.
Great, thanks for your help
There are some simple fet circuits for doing this too, google will find them
( lower voltage drop !)
Diagram in post#2, top one.
The P-channel mosfet Q1 is the "ideal diode".
Leo..
Missed that !
Thanks guys. Doesn't look complicated actually.
Could you help me finding the right reference for the P-Mosfet. Just to be sure. The source of power is between 3.5 and 4.2V and the current is max 180mA.
It could be that Schottky diodes are notorious for high reverse leakage current so would not be ideal for say protection in a battery powered application where the diode is wired in reverse across a fused supply. But, anyway, the P channel mosfet solutions, such as you have shown, are a better solution.
You need a P-MOSFET with a LOW Gate Threshold Voltage
The DMG2301L-7 is a good choice. Mouser for $0.33
Great, thanks @jim-p
Uno/Mega boards use the FDN340P as USB protection diode.
Cheap on ebay if you want large numbers.
Leo..
Thanks @Wawa
