I am interested in making a radar gun, that measure the speed of something in MPH. It can measure in anything really I just need to be able to calculate it into MPH. I would be measuring things like the speed of a car or the speed of a ball.
Thanks
The difference in return time between two pulses will allow you to compute the distance the item traveled in the time between the two pulses. All assuming there is a very small angle between your radar beam and the traveling object.
You are NOT measuring the speed, you are COMPUTING it.
Then you need to determine the frequency and power of the radar transmitter and the sensitivity of the receiver to bounce a signal off a baseball at the maximum distance you want to use. OR you can just get a bunch of different devices and test them.
My experience with radar and baseballs is pretty slip(none).
