Best solution for battery powered Arduino Nano
Hello there!
I read a lot of topic from this and other forums but I don't find a good answer to my problem. I want to power my arduino nano matter/nano 33 IOT with a rechargeable battery. I am not sure if it is better to use AA batteries that are rechargeable or a single cell Li-Ion battery (AKKU SOLD333284: Li-Ion Akku, SOLDERED 333284, 1800 mAh, 3,7 V bei reichelt elektronik) with a MP2636 Power Booster & Charger Module (MP2636 Power Booster & Charger Module — Arduino Official Store). I will power both through the Vin Pin.
Thank you for your help!
I completely agree. I am also not sure which of these batteries would be best for you to use. If only I knew more about you plans.
  • Li-Ion batteries can be dangerous.
  • Suggest you use rechargeable NIMH AA batteries.
However, we need more information.
Safest option would be power bank.
No need for separate charge controller and battery protection circuits.
Thank you for the help already. I want to use the Arduino for controlling small Micro-LED-wire-lights. They need 3-5V and around 7mA per hour. Combined with the Arduino matter this would draw around 25-30mA. After having read these suggestions I will probably use 1.2V, 1.900mAh rechargeable batteries for the one outdoor and a powerbank for the one indoor. Has anyone suggestions for a battery holder?
No sense here. 7 mA is not related to time anyhow. You should post the specs of your micro-led-wire-lights...
Yeah you are right but this all the information I got from the product page. I will just use a big enough battery holder for nimh AA.
