What is the best way to achive a positive 12v signal using arduino as controller?
I'm thinking about using a PNP transistor to use as a switch, so the idea is when the PNP transistor base goes 0v it activate the load.
I think this will work, but when I want to turn off the curcuit, I could change the pin to 1 (HIGH), and I think 5v is not enough to turn the transistor off.
My idea is change pin mode to INPUT when I want to power the circuit off, so the pullup R1 will change the transistor base to 12V.
And when I want to turn the circuit on, I change pin mode to OUTPUT and use DigitalWrite 0
Will it work?
