I am making another stab at trying to understand low-pass filters/audio stuff....
instead of just following schematics, or copying other open source schematics or .brd file..etc....
I have blindly changed values while testing, but it was a true understanding...
I'd like to get a better understanding (IN LAYMEN TERMS) of if raising/lowering this resistor 'here'.. it does/effects this in the output..etc..
(not looking for long big equations or long articles on who invested what and how to calculate things... yet!)
I have a project, SMD board, that I removed some of components and soldered in wires with female, dupont connectors on the other end... so I can easily swap out components/values and test things out..
Here is a snippet of the schematic that applies to the DAC >> AMP >> SPEAKER outputn..
the components circles in RED and the components I can change for testing.. and what the current values I am testing with are..
the components in BLUE are another filter on the back-end... but I havent messed with them ever.. (but can/will if it means getting the best audio I can from this project)
R5/R6 I have a POT wired in so I can dial to whatever.. then measure it and use hard valued resistors...
right now I am getting 'decent' audio.. its not bad... but I 'feel' it could be better with a true understanding instead of randomly messing about..
GOAL:
- best quality and volume I can achieve (fought with volume, muted/muffled sounds, no lows, no highs)
- best filtering for external NOISE (forward thinking about still being able to use my board to PWM leds..so filtering for outside/external noise from leds or something, heard through audio/speaker)
*NOTE: using hobby speakers, un-powered, 1-2watt / 8 Ohm speakers
(clean version)
