Dann habe ich wohl irgendwas nicht verstanden.
Aber wenn der TO glücklich ist, bin ich es auch
Manchmal ist es so, man muss öfters Zwischen den Zeilen lesen.
nur noch ne kleine Frage bei meinem Arduino opla löst der bewegungsmelder wenn ich ihn an schlisse ständig aus was kann ich da machen
"Arduino Opla" ist ein Kit. Der Arduino darin ist ein MKR WiFi1010.
Die Shift-Taste an Deiner Tastatur scheint einen Wackelkontakt zu haben; die Satzzeichen : , ? .
sind kaputt. Solltest Du mal überprüfen und ggf. austauschen.
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/1d0c6f29-b06a-4d92-b346-aee2792e364a
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
String message_update;
bool light_alarm;
bool light_event;
bool movement_alarm;
bool movement_event;
bool shake_alarm;
bool shake_event;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
int pir = A5;
int pirState = 0;
int light = 0;
String light_alarm_state = "";
String movement_alarm_state = "";
String shake_alarm_state = "";
float Gx, Gy, Gz;
uint32_t redColor = carrier.leds.Color( 0, 255, 0);
uint32_t noColor = carrier.leds.Color( 0, 0, 0);
// Initialize serial and wait for port to open: Serial.begin(9600);
// while (!Serial);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
//Wait to get cloud connection to init the carrier
while (ArduinoCloud.connected() != 1) {
ArduinoCloud.update();
CARRIER_CASE = false;
carrier.begin();
carrier.display.setRotation(0);
delay(1500);
pinMode(A5, INPUT);
// Your code here
pirState = digitalRead(pir);
while (!carrier.Light.colorAvailable()) {
delay(5);
int none; //not gonna be used
carrier.Light.readColor(none, none, none, light);
// read the IMU values
carrier.IMUmodule.readGyroscope(Gx, Gy, Gz);
//Uncomment this code to see values in Serial Monitor
Serial.print("Gyroscope: ");
Serial.print("\tX: ");
Serial.print(Gx);
Serial.print("\tY: ");
Serial.print(Gy);
Serial.print("\tZ: ");
Serial.println(Gz);
Serial.print("Light: ");
Serial.println(light);
Serial.print("PIR State: ");
Serial.println(pirState);
delay(200);
//light alarm, can be activated from cloud
if (light_alarm == true) {
if (light > 200) {
light_event = true;
if (light_event == true) {
message_update = "Light alarm breached!";
alarm();
//movement alarm, can be activated from cloud
if (movement_alarm == true) {
if (pirState == LOW) {
movement_event = true;
if (movement_event == true) {
message_update = "Movement alarm breached!";
alarm();
//shake alarm, can be activated from cloud
if (shake_alarm == true) {
if (Gy > 100 || Gy < -100) {
shake_event = true;
if (shake_event == true) {
message_update = "Shake alarm breached!";
alarm();
delay(100);
// the alarm() function blinks the RGB LEDs and turns the buzzer on and off
void alarm() {
carrier.leds.fill(redColor, 0, 5);
carrier.leds.show();
carrier.Buzzer.sound(500);
carrier.leds.fill(noColor, 0, 5);
carrier.Buzzer.noSound();
// the updateScreen() function updates the screen whenever an alarm has been activated from the cloud
void updateScreen() {
carrier.display.fillScreen(ST77XX_BLACK);
carrier.display.setTextColor(ST77XX_WHITE);
carrier.display.setTextSize(2);
carrier.display.setCursor(25, 60);
carrier.display.print(light_alarm_state);
carrier.display.setCursor(10, 100);
carrier.display.print(movement_alarm_state);
carrier.display.setCursor(30, 140);
carrier.display.print(shake_alarm_state);
void onLightAlarmChange() {
// Do something
light_alarm_state = "LIGHT ALARM: ON";
light_alarm_state = "LIGHT ALARM: OFF";
updateScreen();
void onShakeAlarmChange() {
// Do something
shake_alarm_state = "SHAKE ALARM: ON";
shake_alarm_state = "SHAKE ALARM: OFF";
updateScreen();
void onMovementAlarmChange() {
// Do something
movement_alarm_state = "MOVEMENT ALARM: ON";
movement_alarm_state = "MOVEMENT ALARM: OFF";
updateScreen();
void onMessageUpdateChange() {
// Do something
void onLightEventChange() {
// Do something
void onMovementEventChange() {
// Do something
void onShakeEventChange() {
// Do something
Okay, danke.
Bei der Hardware kann man tatsächlich fast nix falsch machen außer den Servostecker verkehrt herum aufzustecken; das sieht aber bei Dir okay aus.
Die Software ist etwas unübersichtlich wegen der Cloud-Anbindung.
Wenn Du sicher bist, dass die Empfindlichkeit niedrig genug eingestellt ist, die Haltezeit (Impulslänge) kürzer ist als die delay()
s in der alarm()
-Funktion (eine Sekunde) und sich nichts bewegt sollte er nur einmal auslösen.
Allerdings würde ich mal in Zeile 72 das INPUT
ändern:
pinMode(A5, INPUT_PULLUP);
Der Sensor ist low aktiv - wenn kein externer Pullup-Widerstand vorhanden ist, hast Du niemanden, der nach der Aktivierung die Leitung wieder auf HIGH
(inaktiv) zieht. Das führt dazu, dass in jedem Durchlauf von loop()
wieder low erkannt und Alarm ausgelöst wird.
auf was würdest du es ändern?
wno158 meint sicher so, wie er es im Post geschrieben hat.
Yep.
Aus INPUT
soll INPUT_PULLUP
werden.
@TO:
Empfindlichkeit kann ich nix zu sagen, hängt von der Umgebung und dem gewünschten Ansprechverhalten ab.
Haltezeit: Da wegen der Alarmfunktion der Sensor alle Sekunde abgefragt wird, muss die Haltezeit unter einer Sekunde sein
O D E R
Es müssen Zustandsübergänge berücksichtigt werden (Alarm frühestens dann wieder auslösen nachdem inaktiv erkannt wurde).
Ansonsten kommt es zu Mehrfachauslösungen. Letzteres wäre im Übrigen sowieso zu empfehlen, dann bleibt der Alarm auch aus wenn der Hamster eine halbe Stunde vor dem Sensor rumturnt.
Das Problem ist leider immer noch da. Das mit dem INPUT_PULLUP habe ich probiert. Aber es hat nicht funktioniert. Wenn ich den Bewegungsmelder an den Opla anschließe dann passiert gar nichts. Außer ich stelle die Dauer des Ausgangssiegnal am Bewegungsmelder ganz auf 1. Dann löst er sofort aus.
Was genau soll das sein ?
Wenn du einen zuverlässigen Bewegungsmelder suchst, dann empfehle ich dir Diesen hier.
#26
Du hast 3 Anschlüsse oder? wurden die anderen ausprobiert ?
Mit dem ganzen großen Sketch wird das nix. Da ich keinen MKR oder gar ein Opla-Kit habe, kann ich es auch nicht ausprobieren.
Probier mal bitte diesen Sketch - und gib uns die Ausgabe vom seriellen Monitor (markieren und mit STRG-C / STRG-V in Code-Tags </>
einfügen). Ich würde gerne erfahren, was Dein Bewegungssensor wirklich macht.
https://forum.arduino.cc/t/bewegungsmelder-ausgangs-signal-zu-lange/986928
const byte pir = A5;
byte pirState = HIGH;
byte lastPirState = HIGH;
unsigned long startZeit;
// while (!Serial);
Serial.println("Los geht's!");
startZeit = millis();
// Your code here
if (pirState != lastPirState)
lastPirState = pirState;
Serial.print(millis() - startZeit);
Serial.println(" aktiv");
Serial.println(" inaktiv");
Ne hab ich noch nicht
17:51:03.574 -> 5155 inaktiv
17:51:06.432 -> 2844 aktiv
17:51:13.884 -> 7448 inaktiv
17:51:16.699 -> 2842 aktiv
17:51:24.048 -> 7320 inaktiv
17:51:26.860 -> 2842 aktiv
17:51:32.323 -> 5469 inaktiv
17:51:35.174 -> 2841 aktiv
17:51:41.067 -> 5864 inaktiv
17:51:43.896 -> 2840 aktiv
17:51:52.174 -> 8297 inaktiv
17:51:55.043 -> 2840 aktiv
17:52:01.161 -> 6157 inaktiv
17:52:04.022 -> 2839 aktiv
Okay, danke.
Du bist siehst vor aktiv
immer Zeiten von etwa 2.84s stehen - konstant. Das wird ausgegeben, wenn der Status am Pin von HIGH
auf LOW
wechselt.
Die Zeiten vor inaktiv
(Wechsel nach HIGH
) sind variabel, also vermutlich dann durch Bewegung verursacht.
Meine Schlußfolgerungen:
LOW
(ich habe mich also in #30 geirrt)This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
