Hi all,
I am using the custom BHI160B board with bmm150.
Board is working fine and I am getting the quaternions as output.
Now I want to implement the TARE to reset the quaternions using this code I got from BNO055 library
if(resetflag)
resetflag = 0;
qoffset[0] = q[0]; //Stored offsets when sent 's' to serial
qoffset[1] = -q[1];
qoffset[2] = -q[2];
qoffset[3] = -q[3];
//q[0]...q[3] are live quaternions from fusion
//qf[0]....qf[3] are tare quaternions using offsets
qf[0] = q[0] * qoffset[0] - q[1] * qoffset[1] - q[2] * qoffset[2] - q[3] * qoffset[3]; // multiplication matrix
qf[1] = q[0] * qoffset[1] + q[1] * qoffset[0] + q[2] * qoffset[3] - q[3] * qoffset[2];
qf[2] = q[0] * qoffset[2] - q[1] * qoffset[3] + q[2] * qoffset[0] + q[3] * qoffset[1];
qf[3] = q[0] * qoffset[3] + q[1] * qoffset[2] - q[2] * qoffset[1] + q[3] * qoffset[0];
//use qf[0..3] to convert to euler angles
This works sometimes and sometimes messes with the values.
I am converting the quats to Euler angles and found pitch is effecting roll and roll effecting pitch if I tare.
is there something wrong with calculations or process?
