hi
i searched a lot to solve this problem and found a few interesting things but not the solution:
Hardware: ESP32C6 with QMI8658
if i understood this right i have to calibrate (because its a 6DOF) the magnetic things with the programm magneto 1.2. So i found this: GitHub - michaelwro/accelerometer-calibration: A general method (with Python scripts) for calibrating accelerometer sensors.
That seems to be nice and working. But where i’m still confused. I want to have a code where i can than use this correctional data.
So i found the code from @jremington with this lines:
// vvvvvvvvvvvvvvvvvv VERY VERY IMPORTANT vvvvvvvvvvvvvvvvvvvvvvvvvvvvv
//These are the previously determined offsets and scale factors for accelerometer and gyro for
// a particular example of an MPU-6050. They are not correct for other examples.
//The AHRS will NOT work well or at all if these are not correct
float A_cal[6] = {265.0, -80.0, -700.0, 0.994, 1.000, 1.014}; // 0..2 offset xyz, 3..5 scale xyz
float G_off[3] = { -499.5, -17.7, -82.0}; //raw offsets, determined for gyro at rest
#define gscale ((250./32768.0)*(PI/180.0)) //gyro default 250 LSB per d/s -> rad/s
// ^^^^^^^^^^^^^^^^^^^ VERY VERY IMPORTANT ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
So it seems that this and the megneto programm corresponds - but how? The output is one 3 values and 2 times 3 rows with 3 values. So the question where tu put what?
I tried a lot of programs but nothing gives me steady roll pitch yaw angles.
Could anyone give me a hint where to find the explanation from going with the magneto callibration values in an Arduino filter code to get rid of the steady changing values?
the nearest code to the problem which works (i get values but these values are not stable and also in the wrong range (roll between -29.7 and +30.7 and pitch between -27.1 and 30.1 and Yaw between -179.9 and +179.9) so YAW seems to work.
The code (i knew that there is only a simple low pass filter):
QMI8658 Advanced Example
This example demonstrates advanced features of the QMI8658 library:
- Motion detection
- Data filtering
- Orientation calculation
- Calibration
Hardware connections:
- VCC to 3.3V
- GND to GND
- SDA to pin 21 (ESP32) or A4 (Arduino)
- SCL to pin 22 (ESP32) or A5 (Arduino)
Author: [Your Name]
#include <QMI8658.h>
#include <math.h>
QMI8658 imu;
// Pin definitions (adjust for your board)
#define SDA_PIN 18 // ESP32 default
#define SCL_PIN 19 // ESP32 default
// Motion detection variables
float accelThreshold = 2.0; // m/s² threshold for motion detection
bool motionDetected = false;
unsigned long lastMotionTime = 0;
// Calibration variables
float accelOffsetX = 0, accelOffsetY = 0, accelOffsetZ = 0;
float gyroOffsetX = 0, gyroOffsetY = 0, gyroOffsetZ = 0;
bool calibrated = false;
// Filter variables (simple low-pass filter)
float filteredAccelX = 0, filteredAccelY = 0, filteredAccelZ = 0;
float filteredGyroX = 0, filteredGyroY = 0, filteredGyroZ = 0;
const float alpha = 0.1; // Filter coefficient (0-1, lower = more filtering)
float min_roll, min_pitch, min_yaw;
float max_roll, max_pitch, max_yaw;
while (!Serial) delay(10);
Serial.println("QMI8658 Advanced Example");
Serial.println("========================");
// Initialize IMU
if (!imu.begin(SDA_PIN, SCL_PIN)) {
Serial.println("❌ Failed to initialize QMI8658!");
Serial.println("Check connections and try again.");
while (1) delay(1000);
Serial.println("✅ QMI8658 initialized successfully!");
Serial.print("Device ID: 0x");
Serial.println(imu.getWhoAmI(), HEX);
// Configure sensor
Serial.println("\n🔧 Configuring sensor...");
imu.setAccelRange(QMI8658_ACCEL_RANGE_8G);
imu.setAccelODR(QMI8658_ACCEL_ODR_1000HZ);
imu.setGyroRange(QMI8658_GYRO_RANGE_512DPS);
imu.setGyroODR(QMI8658_GYRO_ODR_1000HZ);
// Set units
imu.setAccelUnit_mps2(true); // m/s²
imu.setGyroUnit_rads(false); // degrees per second
// Enable sensors
imu.enableSensors(QMI8658_ENABLE_ACCEL | QMI8658_ENABLE_GYRO);
Serial.println("✅ Configuration complete!");
// Perform calibration
performCalibration();
Serial.println("\n📊 Starting sensor readings...");
Serial.println("Time(ms)\tMotion\tRoll\tPitch\tYaw\tAccel_Mag\tGyro_Mag\tTemp(°C)");
Serial.println("-------------------------------------------------------------------------");
QMI8658_Data data;
if (imu.readSensorData(data)) {
// Apply calibration offsets
float accelX = data.accelX - accelOffsetX;
float accelY = data.accelY - accelOffsetY;
float accelZ = data.accelZ - accelOffsetZ;
float gyroX = data.gyroX - gyroOffsetX;
float gyroY = data.gyroY - gyroOffsetY;
float gyroZ = data.gyroZ - gyroOffsetZ;
// Apply low-pass filter
filteredAccelX = alpha * accelX + (1 - alpha) * filteredAccelX;
filteredAccelY = alpha * accelY + (1 - alpha) * filteredAccelY;
filteredAccelZ = alpha * accelZ + (1 - alpha) * filteredAccelZ;
filteredGyroX = alpha * gyroX + (1 - alpha) * filteredGyroX;
filteredGyroY = alpha * gyroY + (1 - alpha) * filteredGyroY;
filteredGyroZ = alpha * gyroZ + (1 - alpha) * filteredGyroZ;
// Calculate orientation (roll, pitch, yaw)
float roll, pitch, yaw;
calculateOrientation(filteredAccelX, filteredAccelY, filteredAccelZ,
filteredGyroX, filteredGyroY, filteredGyroZ,
roll, pitch, yaw);
// Motion detection
float accelMagnitude = sqrt(accelX*accelX + accelY*accelY + accelZ*accelZ);
float gyroMagnitude = sqrt(gyroX*gyroX + gyroY*gyroY + gyroZ*gyroZ);
//checkMotion(accelMagnitude, gyroMagnitude);
if (min_roll > roll) {min_roll = roll;}
if (min_pitch > pitch) {min_pitch = pitch;}
if (min_yaw > yaw) {min_yaw = yaw;}
if (max_roll < roll) {max_roll = roll;}
if (max_pitch < pitch) {max_pitch = pitch;}
if (max_yaw < yaw) {max_yaw = yaw;}
// Print results
// Serial.print(millis());
// Serial.print("\t");
// Serial.print(motionDetected ? "YES" : "NO");
Serial.print("roll: ");
Serial.print(roll, 1);
Serial.print("\t");
Serial.print("pitch: ");
Serial.print(pitch, 1);
Serial.print("\t");
Serial.print("yaw: ");
Serial.print(yaw, 1);
// Serial.print("temperature: ");
// Serial.println(data.temperature, 1);
// Check for calibration command
if (Serial.available()) {
String command = Serial.readString();
command.trim();
if (command == "cal" || command == "calibrate") {
Serial.println("\n🔄 Recalibrating...");
if (command == "max" || command == "min") {
Serial.print("\n min_roll :");
Serial.print(min_roll);
Serial.print("\n min_pitch :");
Serial.print(min_pitch);
Serial.print("\n min_yaw :");
Serial.print(min_yaw);
Serial.print("\n max_roll :");
Serial.print(max_roll);
Serial.print("\n max_pitch :");
Serial.print(max_pitch);
Serial.print("\n max_yaw :");
Serial.println(max_yaw);
delay(50000);
delay(50); // 20Hz update rate
void performCalibration() {
Serial.println("\n🎯 Starting calibration...");
Serial.println("Place the sensor on a flat, stable surface.");
Serial.println("Calibration will start in 3 seconds...");
for (int i = 3; i > 0; i--) {
Serial.print(i);
Serial.println("...");
Serial.println("📈 Collecting calibration data...");
const int numSamples = 1000;
float accelSumX = 0, accelSumY = 0, accelSumZ = 0;
float gyroSumX = 0, gyroSumY = 0, gyroSumZ = 0;
int validSamples = 0;
for (int i = 0; i < numSamples; i++) {
QMI8658_Data data;
accelSumX += data.accelX;
accelSumY += data.accelY;
accelSumZ += data.accelZ;
gyroSumX += data.gyroX;
gyroSumY += data.gyroY;
gyroSumZ += data.gyroZ;
validSamples++;
if (i % 100 == 0) {
Serial.print(".");
delay(10);
if (validSamples > 0) {
// Calculate offsets
accelOffsetX = accelSumX / validSamples;
accelOffsetY = accelSumY / validSamples;
accelOffsetZ = (accelSumZ / validSamples) - 9.81; // Remove gravity
gyroOffsetX = gyroSumX / validSamples;
gyroOffsetY = gyroSumY / validSamples;
gyroOffsetZ = gyroSumZ / validSamples;
calibrated = true;
Serial.println("\n✅ Calibration complete!");
Serial.print("Accel offsets: ");
Serial.print(accelOffsetX, 3); Serial.print(", ");
Serial.print(accelOffsetY, 3); Serial.print(", ");
Serial.println(accelOffsetZ, 3);
Serial.print("Gyro offsets: ");
Serial.print(gyroOffsetX, 3); Serial.print(", ");
Serial.print(gyroOffsetY, 3); Serial.print(", ");
Serial.println(gyroOffsetZ, 3);
Serial.println("💡 Type 'cal' to recalibrate anytime.");
Serial.println("\n❌ Calibration failed! No valid samples collected.");
void calculateOrientation(float ax, float ay, float az,
float gx, float gy, float gz,
float &roll, float &pitch, float &yaw) {
// Calculate roll and pitch from accelerometer
//roll = atan2(ay, sqrt(ax * ax + az * az)) * 180.0 / M_PI;
roll = atan2(ay , az) * 57.3;
//pitch = atan2(-ax, sqrt(ay * ay + az * az)) * 180.0 / M_PI;
pitch = atan2((- ax) , sqrt(ay * ay + az * az)) * 57.3;
// Simple yaw integration from gyroscope (not accurate for long term)
static float yawIntegrated = 0;
static unsigned long lastTime = 0;
unsigned long currentTime = millis();
if (lastTime > 0) {
float dt = (currentTime - lastTime) / 1000.0; // Convert to seconds
yawIntegrated += gz * dt;
lastTime = currentTime;
yaw = yawIntegrated;
// Keep yaw in range [-180, 180]
while (yaw > 180) yaw -= 360;
while (yaw < -180) yaw += 360;
void checkMotion(float accelMag, float gyroMag) {
// Check if current acceleration deviates significantly from gravity
float accelDeviation = abs(accelMag - 9.81);
if (accelDeviation > accelThreshold || gyroMag > 10.0) {
if (!motionDetected) {
Serial.println("\n🚶 Motion detected!");
motionDetected = true;
lastMotionTime = millis();
// No motion for 2 seconds
if (motionDetected && (millis() - lastMotionTime > 2000)) {
Serial.println("🛑 Motion stopped.");
