Big Easy Driver won't reverse
[EDIT]
**SOLVED ** It turns out my pin A4 was not working. I switched to pin A2 and this works fine now.
Here's some very basic code for driving a stepper motor using a Big Easy Driver.
In the example I write HIGH to the dir pin but for some reason regardless of whether I write HIGH or LOW the stepper motor turns in the same direction. I'm wondering if it's somehow related to the fact that I'm using an analog pin.
#define PIN_STEP A5
#define PIN_DIR  A4
#define PIN_ENABLE  A3
  pinMode(PIN_STEP, OUTPUT);
  pinMode(PIN_DIR, OUTPUT);
  pinMode(PIN_ENABLE,OUTPUT);
  digitalWrite(PIN_DIR, LOW);
  digitalWrite(PIN_ENABLE, LOW);
  digitalWrite(PIN_STEP,LOW);
    digitalWrite(PIN_STEP, HIGH);
    delay(1);
    digitalWrite(PIN_STEP, LOW);
    delay(1);
