DIR pin will not reverse stepper?
Hello, I can get the stepper to reverse in the int goBack section ONLY by putting negative numbers in the setacceleration, setMaxSpeed and setSpeed numbers. I want to control it by pulling pin 2 low, which is the direction pin. Any ideas why this code will not produce what I am looking for?
#include <AccelStepper.h>
//A1(15)= Retract switch, cut complete, going low.
//A2= 10k Feedrate Pot 0-5v
//A3(17)= Home Switch
//A4= Rapid to position pot, 10K 0-5V
//A6= Toggle switch to the left, goes low
//A7= Toggle switch in the middle, goes low
//D2= Direction on stepper driver
//D3= Step on stepper driver
//D4= MS3
//D5= MS2
//D6= MS1
//D7= Enable on stepper driver
//D10= Start switch, goes low
AccelStepper stepper(1, 3, 2);
#define MS1 6
#define MS2 5
//#define MS3 5
//#define EN  7
//#define dir 2
  pinMode(10, INPUT);
  pinMode(A1, INPUT);
  pinMode(A3, INPUT);
  pinMode(10, INPUT);
  pinMode(7, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(MS1, OUTPUT);
  pinMode(MS2, OUTPUT);
//  pinMode(MS3, OUTPUT);
  digitalWrite(7, HIGH);
  digitalWrite(2, HIGH);
  int feedValue = ((analogRead(A2)) / 5) + 50;  //FEEDRATE FUNCTION
  int posValue = (1023 - analogRead(A4) * .75 + 500);  //RAPID POSITION FUNCTION
  if (posValue < 300)
    posValue = 300;
  if ((digitalRead(10) == LOW) && (digitalRead(17) == LOW))
  { digitalWrite(7, LOW);
    runIn(posValue, feedValue);
    cut(feedValue, posValue);
  stepper.setCurrentPosition(0);
int runIn(int posValue, int feedValue)
  digitalWrite(MS1, HIGH);
  digitalWrite(MS2, LOW);
  //digitalWrite(MS3, LOW);
  stepper.setAcceleration(2000);
  stepper.setMaxSpeed(2200);
  stepper.setSpeed(2000);
  stepper.runToNewPosition(posValue);
  delay(700);
int goBack()
  digitalWrite(2, LOW);
  while (digitalRead(17) == HIGH)
    digitalWrite(MS1, LOW);
    digitalWrite(MS2, HIGH);
    stepper.setAcceleration(200);
    stepper.setMaxSpeed(5000);
    stepper.setSpeed(500);
    stepper.runSpeed();
int cut(int feedValue, int posValue) {
  int curPos1 = stepper.currentPosition();
  stepper.setMaxSpeed(feedValue);
  //digitalWrite(MS3, HIGH);
  stepper.move(4000);
  while (digitalRead(15) == HIGH && (digitalRead(10) == HIGH)) {
    stepper.run();
  int curPos2 = stepper.currentPosition();
  stepper.stop();
  goBack();
setSpeed with a negative value runs in reverse; that is how you are supposed to do it. You should not be writing to pin 2, that is what AccelStepper does.
In goBack(), stepper.setSpeed(500); should be stepper.setSpeed(-500); to move in reverse.
int goBack()
  digitalWrite(7, LOW);   // Enable stepper driver
  digitalWrite(2, LOW);   // Set direction LOW (Reverse)
  stepper.setSpeed(-500);   // Negative speed to move in reverse
  // Keep running until the home switch (A3) is triggered
    stepper.runSpeed();  // Keep calling runSpeed() to move stepper
  stepper.stop();   // Stop movement once home switch is reached
