Big Fonts for 20 x 4 LCD
I am looking for a font for a digital clock. I have spent about two hours searching and trying stuff, and very little compiles and works with my 20 x 4 LCD with added-on i2c Serial board attached.
I'd like to try numbers 2-lines high and also 4-lines high, but I think if I can find a good enough font, I'll go with two lines of 2-lines.
Any suggestions before I set about reinventing the wheel?
Think about it. Digital clocks often use 7-segment displays.
You have 8 user defined characters that could represent each segment.
If you can design some attractive blobs to imitate each segment, give it a go.
I suggest that you would be better off with a ST7920 style of display. They cost about the same as a 20x4 but can produce a full graphic display. They also use the same pinout. So you could use as nice a big font as you like. (or just use it to print text like a posh 20x4)
David.
Using the term LCD "big font" in the search box at the upper right I came up with this --> LCD "Bigfont" Numbers over 2 or 4 lines - Syntax & Programs - Arduino Forum
Don
floresta:
Thanks Don, but that's one I have already tried before posting. It does not work with my i2c serial lcd.
david_prentice:
Thanks David, but I have the thing fitted in a case with a bunch of other stuff. Also very low on memory after checking a couple of libraries, I'd have to use a Mega. So a rebuild would be the only option and I don't want to do that at this stage. The big font is just a "nice to have" option.
WaitSome:
How doesn't it work ?
Do you get any error messages, and if so show those.
The linked solution is quite old.
See if you can make it work using an IDE older than version 1.0.
Newer versions might be troublesome using older libraries.
Newer Arduino files are *.ino, older are *.pde.
If you run into *.pde files, expect to get that kind of trouble (not meaning *.ino files will not do that).
Hi MAS3, thanks for the thoughts. I got too many errors as that sketch apparently uses LCD4Bit and the one further down uses the standard LiquidCrystal. I need to use the LiquidCrystal_12c library.
I am not skilled enough in C/C++ to adapt either of them. I can post the error message if you like. The Arduino is on another PC so will edit this post from it in a few minutes.
Using Post #7, #8 and #9
Arduino: 1.6.5 (Windows 7), Board: "Arduino/Genuino Uno"
LCD_Big_Font_01.ino: In function 'void printOneNumber2(uint8_t, byte, int)':
LCD_Big_Font_01:53: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:59: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01.ino: In function 'void bigNum(long unsigned int, int, byte, int)':
LCD_Big_Font_01:98: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:99: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:100: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:101: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:102: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:103: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:105: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:106: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:108: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:110: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01.ino: In function 'char* format(long unsigned int)':
LCD_Big_Font_01:136: error: incompatible types in assignment of 'char' to 'char [7]'
LCD_Big_Font_01:139: error: incompatible types in assignment of 'long unsigned int' to 'char [7]'
LCD_Big_Font_01.ino: In function 'void LcdUploadUdef5x8(int, int*)':
LCD_Big_Font_01:155: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01.ino: In function 'void printOneNumber4(uint8_t, byte)':
LCD_Big_Font_01:194: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:200: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:206: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:212: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01.ino: In function 'void bigNum4(long unsigned int, byte, int)':
LCD_Big_Font_01:250: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:251: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:252: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:253: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:254: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:255: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:257: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:258: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:259: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:260: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:261: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:262: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:264: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:265: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:266: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:267: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:268: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:269: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:271: error: 'class LiquidCrystal_I2C' has no member named 'commandWrite'
LCD_Big_Font_01:272: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:274: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
LCD_Big_Font_01:276: error: 'class LiquidCrystal_I2C' has no member named 'printIn'
Using post #11
In file included from D:\ArduinoLib\libraries\LiquidCrystal/LiquidCrystal_I2C.h:35:0,
from LCD_Big_Font_02.ino:1:
D:\ArduinoLib\libraries\LiquidCrystal/LCD.h: In function 'void loadchars()':
D:\ArduinoLib\libraries\LiquidCrystal/LCD.h:513:9: error: 'void LCD::command(uint8_t)' is private
void command(uint8_t value);
LCD_Big_Font_02:115: error: within this context
LCD_Big_Font_02:118: error: call of overloaded 'write(byte [8])' is ambiguous
LCD_Big_Font_02.ino:118:27: note: candidates are:
D:\ArduinoLib\libraries\LiquidCrystal/LCD.h:479:19: note: virtual size_t LCD::write(uint8_t)
virtual size_t write(uint8_t value);
D:\ArduinoLib\libraries\LiquidCrystal/LCD.h:479:19: note: no known conversion for argument 1 from 'byte [8] {aka unsigned char [8]}' to 'uint8_t {aka unsigned char}'
In file included from D:\ArduinoLib\libraries\LiquidCrystal/LiquidCrystal_I2C.h:32:0,
D:\Programs\Arduino\IDE\hardware\arduino\avr\cores\arduino/Print.h:49:12: note: size_t Print::write(const char*)
size_t write(const char str) {
D:\Programs\Arduino\IDE\hardware\arduino\avr\cores\arduino/Print.h:49:12: note: no known conversion for argument 1 from 'byte [8] {aka unsigned char [8]}' to 'const char
LCD_Big_Font_02.ino: In function 'void printbigchar(byte, byte, byte, byte)':
LCD_Big_Font_02:127: error: call of overloaded 'write(byte [3])' is ambiguous
LCD_Big_Font_02.ino:127:33: note: candidates are:
D:\ArduinoLib\libraries\LiquidCrystal/LCD.h:479:19: note: no known conversion for argument 1 from 'byte [3] {aka unsigned char [3]}' to 'uint8_t {aka unsigned char}'
D:\Programs\Arduino\IDE\hardware\arduino\avr\cores\arduino/Print.h:49:12: note: no known conversion for argument 1 from 'byte [3] {aka unsigned char [3]}' to 'const char
within this context
Using the code from message #11, I ran it on my 20x4 I2C display.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 2,  1,  0,  4,  5,  6,  7,  3, POSITIVE);  // .kbv constructor for I2C
byte custchar[8][8] = {
        B11111,
        B11111,
        B11111,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B11111,
        B11111,
        B11111
        B11111,
        B11111,
        B11111,
        B00000,
        B00000,
        B11111,
        B11111,
        B11111
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B01110,
        B01110,
        B01110
        B00000,
        B00000,
        B00000,
        B01110,
        B01110,
        B01110,
        B00000,
        B00000
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000,
        B00000
byte bignums[10][2][3] = {
        {255, 0, 255},
        {255, 1, 255}
        {0, 255, 254},
        {1, 255, 1}
        {2, 2, 255},
        {255, 1, 1}
        {0, 2, 255},
        {1, 1, 255}
        {255, 1, 255},
        {254, 254, 255}
        {255, 2, 2},
        {1, 1, 255}
        {255, 2, 2},
        {255, 1, 255}
        {0, 0, 255},
        {254, 255, 254}
        {255, 2, 255},
        {255, 1, 255}
        {255, 2, 255},
        {254, 254, 255}
void loadchars() {
    for (int i = 0; i < 8; i++)
        lcd.createChar(i, custchar[i]);
    lcd.command(64);
        for (int j = 0; j < 8; j++)
            lcd.write(custchar[j]);
    lcd.home();
void printbigchar(byte digit, byte col, byte row, byte symbol = 0) {
    if (digit > 9) return;
    for (int i = 0; i < 2; i++) {
        lcd.setCursor(col, row + i);
        for (int j = 0; j < 3; j++) {
            lcd.write(bignums[digit][i][j]);     //.kbv add the [i]
        lcd.write(254);
    if (symbol == 1) {
        lcd.setCursor(col + 3, row + 1);
        lcd.write(3);
    } else if (symbol == 2) {
        lcd.setCursor(col + 3, row);
        lcd.write(4);
        lcd.write(4);
    lcd.setCursor(col + 4, row);
    lcd.begin(20, 4);           //.kbv add the begin()
    pinMode(13, OUTPUT);
    loadchars();
    digitalWrite(13, 1);
    printbigchar(0, 0, 0);
    printbigchar(1, 4, 0);
    printbigchar(2, 8, 0);
    printbigchar(3, 12, 0);
    printbigchar(4, 16, 0, 1);
    printbigchar(5, 0, 2);
    printbigchar(6, 4, 2);
    printbigchar(7, 8, 2);
    printbigchar(8, 12, 2);
    printbigchar(9, 16, 2, 2);
void loop() {}
Note that I used the Fmalpartide library and had to amend the code in three places (marked with .kbv)
It does not look very attractive.
The code from message #7, 8, 9 requires a lot of mangling to work with regular libraries, but the pictures in #7 look quite pleasant. I cannot access GitHub - designer2k2/multidisplay: The MultiDisplay Project, An opensource datalogger, boost controller and display for cars
If I could access that site, it should be be fairly straightforward to get the sketch running on your display.
David.
In case you are interested, I have a 'big font' (double height really) for numbers in a sketch on my arduino libraries site (see links below).
I second that, also "as is" you would have max 4 digits clock - each digit takes 2 lines by 4 blocks.
Six digit clock just does not fit into 20 x 4 LCD.
But I would suggest this as a "school project" - bouncing clock AKA the old and original "ping pong game".
I think it would be more of a challenge than the common "push button and blink LED" stuff.
I have build an NMEA display with an Arduino Nano. I used the code to print big fonts from whosawhatsis in this topic: LCD "Bigfont" Numbers over 2 or 4 lines - Syntax & Programs - Arduino Forum. I changed some code, to print dashes and commas. I used it with a 16x4 lcd. Here is my code.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
   B00000,
   B00000,
   B00000,
   B00000,
   B00011,
   B01111,
   B01111,
   B11111
   B00000,
   B00000,
   B00000,
   B00000,
   B11000,
   B11110,
   B11110,
   B11111
   B00000,
   B00000,
   B00000,
   B00000,
   B11111,
   B11111,
   B11111,
   B11111
   B11111,
   B01111,
   B01111,
   B00011,
   B00000,
   B00000,
   B00000,
   B00000
   B11111,
   B11110,
   B11110,
   B11000,
   B00000,
   B00000,
   B00000,
   B00000
   B11111,
   B11111,
   B11111,
   B11111,
   B00000,
   B00000,
   B00000,
   B00000
   B11111,
   B11111,
   B11111,
   B11111,
   B11100,
   B11000,
   B10000,
   B00000
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000,
   B00000
byte bignums[13][4][3] =
   {0,   2,   1},
   {255, 254, 255},
   {255, 254, 255},
   {3,   5,   4}
   {2,   1,   254},
   {254, 255, 254},
   {254, 255, 254},
   {5,   5,   5}
   {0,   2,   1},
   {0,   2,   255},
   {255, 254, 254},
   {5,   5,   5}
   {0,   2,   1},
   {254, 2,   255},
   {254, 254, 255},
   {3,   5,   4}
   {2,   254, 254},
   {255, 2,   2},
   {254, 255, 254},
   {254, 5,   254}
   {2,   2,   2},
   {255, 2,   2},
   {254, 254, 255},
   {5,   5,   4}
   {0,   2,   1},
   {255, 2,   1},
   {255, 254, 255},
   {3,   5,   4}
   {2,   2,   2},
   {254, 2,   255},
   {254, 255, 254},
   {254, 5,   254}
   {0,   2,   1},
   {255, 2,   255},
   {255, 254, 255},
   {3,   5,   4}
   {0,   2,   1},
   {255, 254, 255},
   {3,   5,   255},
   {254, 254, 5}
   {254, 254, 254},
   {254, 254, 254},
   {254, 254, 254},
   {6,   254, 254}
   {254, 254, 254},
   {2,   2,   2},
   {254, 254, 254},
   {254, 254, 254}
   {254, 254, 254},
   {254, 254, 254},
   {254, 254, 254},
   {254, 254, 254}
void loadchars()
void printbigchar(char digit, byte col)
  char chars [] = "0123456789.- ";
  int offset = -1;
  for (int i=0; i<strlen(chars); i++)
    if (chars[i] == digit)
      offset = i;
  if (offset < 0)
    return;
  for (int i = 0; i < 4; i++)
    lcd.setCursor(col, i);
      if (digit == '.' && j == 1) break;
      lcd.write((byte)(bignums[offset][i][j]));
void printbigbuffer(char *buffer)
  for (int i=strlen(buffer)-1; i>=0; i--)
    printbigchar(buffer[i], (i + 1) * 4 + 1);
Hello, I am very new to code and arduino but love to learn. I got a 2004 LCD and found some big font code and it works great. I even combined it with DHT22 code for temp and humidity. My problem is that I can only get things in " " to print in big font on the LCD. I don't know how to get the values from the DHT22 to display in big font. Anyone know how to do this?? Thanks
