I want to make a calculator that only I can use because you have to put the question in binary and the answer will come out in base ten. I found a guy that made a Arduino calculator on the Arduino hub but I cant understand the code so I cant take the part that switches binary to base ten out. please help
The code was
* Arduino Keypad calculator Program
#include <LiquidCrystal.h> //Header file for LCD from https://www.arduino.cc/en/Reference/LiquidCrystal
#include <Keypad.h> //Header file for Keypad from https://github.com/Chris--A/Keypad
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'7','8','9','D'},
{'4','5','6','C'},
{'1','2','3','B'},
{'*','0','#','A'}
byte rowPins[ROWS] = { 0, 1, 2, 3 };// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte colPins[COLS] = { 4, 5, 6, 7 }; // Connect keypad COL0, COL1 and COL2 to these Arduino pins.
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS ); // Create the Keypad
const int rs = 8, en = 9, d4 = 10, d5 = 11, d6 = 12, d7 = 13; //Pins to which LCD is connected
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
long Num1,Num2,Number;
char key,action;
boolean result = false;
lcd.begin(16, 2); //We are using a 16*2 LCD display
lcd.print("DIY Calculator"); //Display a intro message
lcd.setCursor(0, 1); // set the cursor to column 0, line 1
lcd.print("-CircuitDigest"); //Display a intro message
delay(2000); //Wait for display to show info
lcd.clear(); //Then clean it
key = kpd.getKey(); //storing pressed key value in a char
if (key!=NO_KEY)
DetectButtons();
if (result==true)
CalculateResult();
DisplayResult();
void DetectButtons()
if (key=='*') //If cancel Button is pressed
{Serial.println ("Button Cancel"); Number=Num1=Num2=0; result=false;}
if (key == '1') //If Button 1 is pressed
{Serial.println ("Button 1");
if (Number==0)
Number=1;
Number = (Number*10) + 1; //Pressed twice
if (key == '4') //If Button 4 is pressed
{Serial.println ("Button 4");
if (Number==0)
Number=4;
Number = (Number*10) + 4; //Pressed twice
if (key == '7') //If Button 7 is pressed
{Serial.println ("Button 7");
if (Number==0)
Number=7;
Number = (Number*10) + 7; //Pressed twice
if (key == '0')
{Serial.println ("Button 0"); //Button 0 is Pressed
if (Number==0)
Number=0;
Number = (Number*10) + 0; //Pressed twice
if (key == '2') //Button 2 is Pressed
{Serial.println ("Button 2");
if (Number==0)
Number=2;
Number = (Number*10) + 2; //Pressed twice
if (key == '5')
{Serial.println ("Button 5");
if (Number==0)
Number=5;
Number = (Number*10) + 5; //Pressed twice
if (key == '8')
{Serial.println ("Button 8");
if (Number==0)
Number=8;
Number = (Number*10) + 8; //Pressed twice
if (key == '#')
{Serial.println ("Button Equal");
Num2=Number;
result = true;
if (key == '3')
{Serial.println ("Button 3");
if (Number==0)
Number=3;
Number = (Number*10) + 3; //Pressed twice
if (key == '6')
{Serial.println ("Button 6");
if (Number==0)
Number=6;
Number = (Number*10) + 6; //Pressed twice
if (key == '9')
{Serial.println ("Button 9");
if (Number==0)
Number=9;
Number = (Number*10) + 9; //Pressed twice
if (key == 'A' || key == 'B' || key == 'C' || key == 'D') //Detecting Buttons on Column 4
Num1 = Number;
Number =0;
if (key == 'A')
{Serial.println ("Addition"); action = '+';}
if (key == 'B')
{Serial.println ("Subtraction"); action = '-'; }
if (key == 'C')
{Serial.println ("Multiplication"); action = '*';}
if (key == 'D')
{Serial.println ("Devesion"); action = '/';}
delay(100);
void CalculateResult()
if (action=='+')
Number = Num1+Num2;
if (action=='-')
Number = Num1-Num2;
if (action=='*')
Number = Num1*Num2;
if (action=='/')
Number = Num1/Num2;
void DisplayResult()
lcd.setCursor(0, 0); // set the cursor to column 0, line 1
lcd.print(Num1); lcd.print(action); lcd.print(Num2);
if (result==true)
{lcd.print(" ="); lcd.print(Number);} //Display the result
lcd.print(Number); //Display the result
The part that does the input is the DetectButtons function. To make this binary you just need to have the keys 0 and 1 detected, so delete the other key actions.
The
Should be replaced with
Number = (Number*2) + 1; //Pressed twice
For both remaining number keys.
That code looks way too long.
TheMemberFormerlyKnownAsAWOL:
Indeed. Even if we ignore the all the duplication for the number buttons (which could be a single bit of code)...
if (Number==0)
Number=8;
Why the special case for when 'Number==0'?
Ask yourself....
What is the result of 'Number = (Number*10) + 8' when Number == 0?
Probably something like...
if (key >= '0' && key <= '9') //If Button 0..9 pressed
Serial.print("Button ");
Serial.println(key);
Number = (Number * 10) + (key - '0');
Or as the OP wants binary input, something like...
if (key >= '0' && key <= '1') //If Button 0..1 pressed
Number = (Number * 2) + (key - '0');
[/code]
Just this would save a lot of code
{'7','8','9','/'},
{'4','5','6','*'},
{'1','2','3','-'},
{'C','0','=','+'}
or if all you want is binary
{'1',' ',' ','-'},
{'C','0','=','+'}
I want to make a calculator but the math problem you put into it is in binary but the answer is in base 10, and I found a guy on the Arduino hub that made a calculator, but I don't understand the code so I cant take the part out that is making base 10 convert to binary. here's the code he was using
{'7','8','9','D'},
{'4','5','6','C'},
{'1','2','3','B'},
{'*','0','#','A'}
char key,action;
if (key!=NO_KEY)
DetectButtons();
if (result==true)
CalculateResult();
DisplayResult();
if (Number==0)
Number=1;
if (Number==0)
Number=4;
if (Number==0)
Number=7;
if (key == '0')
if (Number==0)
Number=0;
if (Number==0)
Number=2;
if (key == '5')
if (Number==0)
Number=5;
if (key == '8')
if (Number==0)
Number=8;
if (key == '#')
Num2=Number;
result = true;
if (key == '3')
if (Number==0)
Number=3;
if (key == '6')
if (Number==0)
Number=6;
if (key == '9')
if (Number==0)
Number=9;
Num1 = Number;
Number =0;
if (key == 'A')
if (key == 'B')
if (key == 'C')
if (key == 'D')
delay(100);
if (action=='+')
Number = Num1+Num2;
if (action=='-')
Number = Num1-Num2;
if (action=='*')
Number = Num1*Num2;
if (action=='/')
Number = Num1/Num2;
if (result==true)
Why are you starting a new thread? Cross posted here. Cross posting wastes time. Cross post reported.
Also not really an electronics issue
snàithleanan air an aonachadh
