Bipolar Stepper Motor with unavailable datasheet questions
Hello all.
I currently have two Sonceboz 6231 R079 bi-polar stepper motors from an electronic speedometer, wich i would like to connect to Arduino.
I've been looking for their datasheet online, but to no avail.
The only two specs i know are the 0.17 Amperes per phase rating and 70 ohms (as they're printed on the stator case).
I'm opening this thread as i need to precisely confirm just the following things:
  • These two stepper motors cannot be powered directly via the Arduino power supply, but need a separated external supply, correct? Given the available specs, what would be best in my case? 12v?
  • For bi-polar stepper motors, should i use the SN754410ne H-Bridge as listed in the arduino guide or are there other micocontrollers i should look at?
Thank you all for your time!
The SN54410ne is a very old bi-polar part with a high voltage drop. There are much more efficient MOSFET drivers available. Pololu (Pololu - Stepper Motor Drivers) is one provider of motor controllers. They have a confusing number of possibilities. Probably someone else on the forum has a recommendation. It has been decades since I used a stepper so my knowledge is limited to obsolete technology.
No expert on motors.
Found a global spec link, with an option to get detailed info by registering.
https://datasheets.globalspec.com/ds/sonceboz/6231-a/96384747-b05d-42d3-a154-dea18e0ded42
Yes, No Arduino can directly drive motors. As it has 2 coils I assume you should be able to drive it with a A4988 driver / equivalent or more modern driver. Use a cooling element as these drivers might get hot.
The global spec above states 0.17-0.34 Amps and the R = 70 Ohm => 0.17 * 70
So 12V should work.
No idea,
No, I don't see a problem with that, provided the power supply is adequately rated.
I would be more worried about powering the Arduino with 12V. Depending on the model you use (you forgot to mention that), pulling more than a small current from the 5V pin can overload the Arduino's regulator.
What does Ohm's law tell you, knowing the current and coil resistance?
You can get those two high impedance motors going with an Adafruit motorshield v2, plugged on top of an Uno R3.
Get x-27 steppers , used in speedos etc , there a driver chip available and can driven from the uno 5v.
The effort is getting an unknown working is , well, not worth it .
£6-7 each eBay
Driver chip :AX1201728SG
+1
There is a Switec library for those motors, and they can be driven directly from Arduino pins.
I managed to drive four of those motors directly from a single Nano v3.
No drivers needed.
Hi, @socimi
It sounds like you have as @hammy has suggested a X-27 air cored stepper.
Can you please post some images of the device, so we can more accurate in identifying this stepper.
I have also used the Switec library and direct driven the stepper from Arduino outputs.
Tom.... :smiley: :+1: :coffee: :australia:
Those drivers are for high current/low impedance motors. Op has high impedance (70 Ohm) motors.
If torque at high speed is not required, then they can be driven with common (mosfet) H-bridges, powered with 12volt.. The TB6612 is a good option. They are used on the Adafruit shield I mentioned.
@Wawa
Thanks for explaining
IMO these are well worth looking into - only 2 wire connection to the processor - one sets direction, the other you pulse to move it . No library required .
One chip can drive 4 steppers .
