a Very warm greeting to all.
As a very NEW researcher in magnetic & frequency energy, with very little electronic board developing experience, I need the help of people who KNOWS in the Arduino Forum.
Can someone please help develope a BLDC PWM sensless Motor Controller that I can change all input manually for research purposes.
What I need is a PCBoard combination of the motor power driver & the Frequency Driver with all protections ie. BEMF, current and what is needed for protection on the board.
Also what will be a winner with the LCD monitor inluded with all of the INPUTS:
- V - A - Freq - RPM - Heat in Celcius
OUTPUT:
- V - A - Freq - Heat in Celcius
The input power 200 - 240VAC rectified to DC PWM Power driver and the volts VARIABLE from 0V - 240VDC with the LCD knobs changeable in 12VDC intervals and at least 10A circuitry with protection build in.
The Freq board combined to the power driver where the Duty Cycle & the Frequencies is variable seperately not effecting each other in the settings from 1% - 99%.
The Frequency settings from 1Hz - 16Mhz with 10Hz interchangeable settings for certain
range of frequencies. (Mega 2560 & Uno Ref 3).. Maybe the coding will control the manual settings.... I am not sure with a lack of knowledge.
This Bridge High Power High Torque Power driver must be controlled either by the Arduino Mega 2560 and/or Uno Ref 3, with a JUMPER setting on the Power Board to change the board output settings from single phase to 3 phase outputs and visa versa.
I presume that the only difference will be the coding and pin relationships to each other of the Arduino boards.
At last but not the least, is all the connections diagram of the Combined Power Driver & Freg Driver board onto the Arduino Mega 2560 and/or Uno ref 3
Attached link with more details of one of these drivers and circuit.
BLDC sensorless Motor Controller & Frequency drive.
Hope you people out there can support and help me with this research project.
Looking forward to hear from anybody who are prepare to help.
I will gratefully accept circuit diagrams in Gerber file for manufacturing.
Warm Greetings & Blessings from out the Lovely South Africa.
Gert.
