BLDC RPM and Duration Control
Hello, I'm trying to make a program to control the speed and duration of bldc according to the json command that I entered, the first time I used the json command the motor could run according to command but after the process was finished and I tried using the command again the second time the motor wouldn't. is there an error or someting wrong in my code? thanks
#include <ArduinoJson.h>
//{"start": true}
//{"start": false}
//{"set_rpm": 200}
//{"set_duration": 5000}
int VR = 11;
unsigned long startTime = 0;
unsigned long duration = 0;
int targetRPM = 0;
bool motorStarted = false;
bool processFinished = false;
bool manualStop = false;
  pinMode(VR, OUTPUT);
  Serial.println("Enter RPM and Duration before start:");
  if (Serial.available()) {
    String input = Serial.readStringUntil('\n');
    DynamicJsonDocument doc(128);
    deserializeJson(doc, input);
    if (doc.containsKey("start")) {
      bool start = doc["start"];
      if (start) {
        startMotor();
        stopMotor();
    if (doc.containsKey("set_rpm")) {
      targetRPM = doc["set_rpm"];
      Serial.print("RPM : ");
      Serial.println(targetRPM);
    if (doc.containsKey("set_duration")) {
      duration = doc["set_duration"];
      Serial.print("Durasi : ");
      Serial.print(duration / 1000);
      Serial.println(" detik");
  if (motorStarted && !manualStop && (millis() - startTime >= duration)) {
    stopMotor();
  if (motorStarted && !manualStop) {
    Serial.print("Durasi: ");
    Serial.print((millis() - startTime) / 1000);
  if (processFinished) {
    Serial.println("Finish");
    manualStop = false;
    Serial.println("Enter JSON Command to start motor:");
void startMotor() {
  if (motorStarted) {
    Serial.println("Motor is already running");
    return;
  if (targetRPM <= 0 || duration <= 0) {
    Serial.println("Before start be sure the rpm and duration is already set");
    return;
  int speed = map(targetRPM, 0, 5000, 50, 250);
  analogWrite(VR, speed);
  startTime = millis();
  motorStarted = true;
  manualStop = false;
  Serial.println("BLDC Start");
void stopMotor() {
  digitalWrite(VR, LOW);
  processFinished = true;
  manualStop = true;
what output do you see?
the duration is showed up at the serial monitor until the process is finish
gambar
don't understand how showing some prints of the duration answers my question
i see the following
startMotor:
 BLDC Start
stopMotor:
 Finish
startMotor:
 BLDC Start
stopMotor:
 Finish
with this code
//{"start": true}
//{"start": false}
//{"set_rpm": 200}
int VR = 11;
unsigned long duration = 1000;
int  targetRPM = 500;
#if 1
        char buf [80];
        Serial.readBytesUntil('\n', buf, sizeof(buf));
        if (strstr (buf, "start"))
            startMotor();
        else if (strstr (buf, "stop"))
            stopMotor();
        else if (strstr (buf, "duration")) {
            sscanf (buf, "%*s %lu", & duration);
#else
            if (start) {
                startMotor();
                stopMotor();
#endif
        stopMotor();
#if 0
#endif
        Serial.println(" Finish");
        manualStop      = false;
void startMotor() {
    Serial.println ("startMotor:");
    if (motorStarted) {
        Serial.println(" Motor is already running");
        return;
        Serial.println(" Before start be sure the rpm and duration is already set");
        return;
    manualStop   = false;
    Serial.println(" BLDC Start");
void stopMotor() {
    Serial.println ("stopMotor:");
    manualStop = true;
sorry, i mean i want the motor to start running again when the first process is already done. But every time i enter the json again after the first process is done the motor wont run until i reupload the code.
please post your output
RPM : 200
Durasi : 5 detik
BLDC Start
//Counting from 1 to 5 second
Finish
Like that sir ?
