BLE scan not detecting on rp2040 connect
Hello everyone hope you doing all well, i was trying to set a BLE connection between two arduino rp 2040 in my app ( depending on user input it will chose which technology to start), the BLE peripheral is working just fine and connected to it via bluetooth scanner app, the problem is that my code for the central which needs to detect the peripheral and retrieve RSSI doesn t work, any help please ? , here s the code :
 if (strcmp(selectedMode, "Mode 7") == 0 && !isScanDone) {
        BLEDevice peripheral;
        do {
            // Start scanning for BLE peripherals with the specific service UUID
            BLE.scanForUuid("180D");
            // Check if a peripheral has been discovered
            peripheral = BLE.available();
            // Print a dot to indicate scanning
            Serial.print(".");
            // Delay to throttle the scanning process and allow some CPU time for other operations
            delay(100);
        } while (!peripheral);  // Continue until a peripheral is found
        // Stop scanning
        BLE.stopScan();
        if (peripheral) {
            // Check if the peripheral actually has the service UUID
            if (peripheral.hasService("180D")) {
                int rssi = peripheral.rssi();
                Serial.print("RSSI: ");
                Serial.println(rssi);
                Serial.println("Device found, but does not have the required service.");
                // Optional: Restart the scanning if necessary
                isScanDone = false;  // Set to false to allow rescanning
            Serial.println("No device found.");
        // Set the flag to true to prevent re-entry if no need to rescan
        isScanDone = true;
