Blink only 10 times
Hi Folks,
A buddy of mine wrote me this code to blink an LED with a Start and Stop push button. I was hoping to have this code so it only blinks 10 times when pressed start, rather than having it blink indefinitely, and stops after 10 blinks or when Stop is pressed. All help is appreciated!!
Here is what I have:
const int ledPin = 5;
const int buttonApin = 9;
const int buttonBpin = 8;
const unsigned long interval = 1000;
boolean Blinking = false;
boolean ledState = false;
unsigned long previousMillis = 0;
pinMode(ledPin, OUTPUT);
pinMode(buttonApin, INPUT_PULLUP);
pinMode(buttonBpin, INPUT_PULLUP);
if (digitalRead(buttonApin) == LOW)
Blinking = true;
if (digitalRead(buttonBpin) == LOW)
Blinking = false;
if (Blinking)
if (currentMillis - previousMillis >= interval)
  // save the last time you blinked the LED
  // if the LED is off turn it on and vice-versa:
  ledState = !ledState;
  // set the LED with the ledState of the variable:
  digitalWrite(ledPin, ledState);
} // end if (Blinking)
Hello wannabetechsavvyo
try and check this proposal:
    Blinking = true;
  static int blinkCount = 10;
    Blinking = false;
  if (Blinking)
    if (currentMillis - previousMillis >= interval )
      // decrement blink counter
      blinkCount--;
      if (blinkCount == 0) Blinking = false;
Hi @paulpaulson,
I tried it and it seem to work the first time i press Start. But then if press start again the blinking is indefinite.
try this.
    Blinking = true;
    Blinking = false;
  if (Blinking)
      blinkCount--;
just make Blink a counter
consider
int  Blinking;
void setup ()
    pinMode (ledPin, OUTPUT);
    pinMode (buttonApin, INPUT_PULLUP);
    pinMode (buttonBpin, INPUT_PULLUP);
void loop ()
        Blinking = 20;
        Blinking = 20;
    if (Blinking)
        unsigned long currentMillis = millis ();
            Blinking--;
            digitalWrite (ledPin, ledState);
Hi @gcjr
I tried the code you put here but the STOP button doesn't work anymore. when i press stop it again restarts the sequence.
Hi @paulpaulson
Tried the code you did too, but its functioning just as the original code i had. The only part it is missing is that it need to blink only 10 times and stop or whenever STOP is pressed.
sorry. i misunderstood what you wanted stop to do
just set Blink to 0 when the B pin is pressed
Hi @gcjr
I did that and it works fine, just the way i thought of it to be. One quick question though, how do i make sure that after every time the LED blinks and stops after 10 blinks, it stops at a low? coz currently , when i press START the first time it blinks does stop blinking at HIGH and the once i press START again it it blinks does stop blinking at LOW. The third time it will end at a HIGH and so on
Add 1 to the count?
Post the code you are using
you can set the starting and stopping states when the buttons are pressed
Hi @pmagowan
if i add 1 to the count wouldn't it only change the subsequent iterations? I am little confused by that.
Here is the code I have so far with the help that I've gotten so far. Does 10 blinks but all the odd number iterations (one iteration is 10 blinks) ends in LED HIGH.
const unsigned long interval = 300;
int Blinking;
void setup ()
void loop ()
Blinking = 20;
    Blinking = 0;
if (Blinking)
        Blinking--;
what is the pin initialized to?
think things over and figure out what needs to be done to meet your requirements
Hi @gcjr
Think i got it how I wanted it to be. I randomly tried making Blinking = 19 instead of Blinking = 20 and it seem to work just fine.
Thanks a lot guys for all the help. Very much a beginner to programming, and I appreciate all the help and guidance that I got here.
Cheers!!
