Running a LED flash loop with a start/stop button
I'm very new to programming, and struggling with a code set. I'm trying to run a simple LED flash sequence. I want it to start when the push button is pressed, and run, until it is pressed again. I can only get it to run once, and not loop continuously.
Any help is appreciate.
-Wrench
#define LED1 13
#define LED2 12
#define LED3 11
#define BUTTON_PIN 6
byte lastButtonState;
byte ledState = LOW;
unsigned long lastTimeButtonStateChanged = millis();
unsigned long debounceDuration = 50; // millis
const int delayTime = 200;
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(BUTTON_PIN, INPUT);
  lastButtonState = digitalRead(BUTTON_PIN);
  if (millis() - lastTimeButtonStateChanged >= debounceDuration){
  byte buttonState = digitalRead(BUTTON_PIN);
    if (buttonState != lastButtonState){
    lastButtonState = buttonState;
    if (buttonState == LOW) {
      digitalWrite(LED1, HIGH); // Turn LED 1 on
     delay(delayTime);
      digitalWrite(LED1, LOW);  // Turn LED 1 off
      digitalWrite(LED2, HIGH); // Turn LED 2 on
      delay(delayTime);
      digitalWrite(LED2, LOW);  // Turn LED 2 off
      digitalWrite(LED3, HIGH); // LED 3 ON
      delay(delayTime);
      digitalWrite(LED3, LOW);
#define LED1 13
#define LED2 12
#define LED3 11
#define delayTime  200
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  if (!digitalRead(BUTTON_PIN))
    delay(delayTime);
    delay(delayTime);
    delay(delayTime);
    while (!digitalRead(BUTTON_PIN));
Unfortunately this didn't solve the issue. Does it matter that this is an Uno R3?
I still get one run of the LEDs and then it stops. I don't get the loop of the LEDs continuously.
you said: one press - one run
My bad. I meant. One press, continuous run until pressed again.
#define LED1 13
#define LED2 12
#define LED3 11
  static bool isActive = false;
  if (!digitalRead(BUTTON_PIN)) {
    isActive = !isActive;
    delay(20);
  if (isActive)  {
    delay(delayTime);
    delay(delayTime);
    delay(delayTime);
updated
OR ....
Hello heli_wrench
Welcome to the best Arduino forum ever :slight_smile:
What is the task of the sketch in real life?
#define LED1 13
#define LED2 12
#define LED3 11
#define BUTTON_PIN 2    //     <------   attention <-----  pin changed, very important
volatile bool didPressed = false;
  attachInterrupt(digitalPinToInterrupt(BUTTON_PIN), change, FALLING);
void change() {
   if (!didPressed)didPressed = true;
  if (didPressed) {
    delay(20);
    didPressed = false;
  if (isActive)  {
    delay(delayTime);
    delay(delayTime);
    delay(delayTime);
or even:
const byte LEDs[] = {13, 12, 11};
   for (byte i = 0; i < sizeof(LEDs); i++)pinMode(LEDs[i], OUTPUT);
void change() {
  static uint32_t oldMillis = 0;
  static byte index = 0;
  if (didPressed) {
    delay(20);
    digitalWrite(LEDs[index], HIGH);
    oldMillis = millis();
    didPressed = false;
  if (isActive)  {
    if (millis() - oldMillis >= delayTime) {
      digitalWrite(LEDs[index], LOW);
      index = (1+index) % sizeof(LEDs);
  else for (byte i = 0; i < sizeof(LEDs); i++)digitalWrite(LEDs[i], LOW); // when this line commented out then leds will not cleared at stop
Perfect thanks. This worked.
