Blinking RGB LED without delay
Hello everyone, I have a doubt about how can I blink a RGB LED but using millis()
for example, I want to do the following:
int pinRed = 3;
int pinGrn = 5;
int pinBlu = 6;
  pinMode(pinRed, OUTPUT);
  pinMode(pinGrn, OUTPUT);
  pinMode(pinBlu, OUTPUT);
  redColor();
  greenColor();
  blueColor();
void redColor(){
  digitalWrite(pinRed, LOW);
  digitalWrite(pinGrn, HIGH);
  digitalWrite(pinBlu, HIGH);
void greenColor(){
  digitalWrite(pinGrn, LOW);
  digitalWrite(pinRed, HIGH);
void blueColor(){
  digitalWrite(pinBlu, LOW);
...but using millis();
I have this code
int pinRed = 3;
int pinGrn = 5;
int pinBlu = 6;
unsigned long previousMillis = 0;
unsigned long previousMillis1 = 0;
unsigned long previousMillis2 = 0;
//Function Prototype
void redColor();
void greenColor();
void blueColor();
void flash(unsigned long);
   flash(currentMillis);
void redColor(){
void greenColor(){
void blueColor(){
void flash(unsigned long thisMillis){
  if (((thisMillis - previousMillis) >= 1000)){
    previousMillis = thisMillis;
    redColor();
  if ((thisMillis - previousMillis1) >= 2000){
    previousMillis1 = thisMillis;
    greenColor();
  if ((thisMillis - previousMillis2) >= 3000){
    previousMillis2 = thisMillis;
    blueColor();
but it does not work as expected.
At the begining the sequence is:
red, green blue, green, red, blue, red, green, blue, green, red, blue...
I would really appreciate if someone can guide me
The millis code has too many timers..
You got 3, 1 for each of the leds..
Thus they can be controlled separately..
Really if you want the millis to work like the blocking delay code..
you need 1 millis timer, the first with 1000 a second..
then a simple byte var to keep track of which led you blink..
could do a switch case, then, ++ your var, reset var after blue..
byte CurrentColor = 0;
void flash(unsigned long thisMillis) {
  if (((thisMillis - previousMillis) >= 1000)) {
    switch (CurrentColor) {
      case 0: redColor(); CurrentColor++; break;
      case 1: greenColor(); CurrentColor++; break;
      case 2: blueColor(); CurrentColor = 0; break;
have fun.. ~q
It works!!!
You are the BEST!
Thank you very much! I'm very grateful
