Hi
I am doing blood pressure monitor for my project and i tried to use the example provided, but the serial monitor did not come out the result shown but it turn out to be as the photo below. I am not sure what is the problem. NEED HELP!
Thank You ![]()
* eHealth sensor platform for Arduino and Raspberry from Cooking-hacks.
* Description: "The e-Health Sensor Shield allows Arduino and Raspberry Pi
* users to perform biometric and medical applications by using 9 different
* sensors: Pulse and Oxygen in Blood Sensor (SPO2), Airflow Sensor (Breathing),
* Body Temperature, Electrocardiogram Sensor (ECG), Glucometer, Galvanic Skin
* Response Sensor (GSR - Sweating), Blood Pressure (Sphygmomanometer) and
* Patient Position (Accelerometer)."
* In this example we are going to get data stored in the blood pressure sensor
* memory and show the result in the serial monitor.
* Copyright (C) 2012 Libelium Comunicaciones Distribuidas S.L.
* http://www.libelium.com
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/> .
* Version 2.0
* Author: Ahmad Saad & Luis Martin
#include <eHealth.h>
eHealth.readBloodPressureSensor();
delay(100);
uint8_t numberOfData = eHealth.getBloodPressureLength();
Serial.print(F("Number of measures : "));
Serial.println(numberOfData, DEC);
delay(100);
for (int i = 0; i<numberOfData; i++) {
// The protocol sends data in this order
Serial.println(F("=========================================="));
Serial.print(F("Measure number "));
Serial.println(i + 1);
Serial.print(F("Date -> "));
Serial.print(eHealth.bloodPressureDataVector[i].day);
Serial.print(F(" of "));
Serial.print(eHealth.numberToMonth(eHealth.bloodPressureDataVector[i].month));
Serial.print(2000 + eHealth.bloodPressureDataVector[i].year);
Serial.print(F(" at "));
if (eHealth.bloodPressureDataVector[i].hour < 10) {
Serial.print(0); // Only for best representation.
Serial.print(eHealth.bloodPressureDataVector[i].hour);
Serial.print(F(":"));
if (eHealth.bloodPressureDataVector[i].minutes < 10) {
Serial.print(0);// Only for best representation.
Serial.println(eHealth.bloodPressureDataVector[i].minutes);
Serial.print(F("Systolic value : "));
Serial.print(30+eHealth.bloodPressureDataVector[i].systolic);
Serial.println(F(" mmHg"));
Serial.print(F("Diastolic value : "));
Serial.print(eHealth.bloodPressureDataVector[i].diastolic);
Serial.print(F("Pulse value : "));
Serial.print(eHealth.bloodPressureDataVector[i].pulse);
Serial.println(F(" bpm"));
delay(20000);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
