As I am new in the world of arduino. So I did not have much knowledge about arduino. I want to create blood pressure measurement system using HX710B for project. Can anyone help me in this topic.
You mean HX710B ?
It's analog to digital converter, it doesn't measure anything. You still need a pressure sensor.
Why you need to use that specific ADC? Saw some tutorial doing that?
This sensor
is designed to measure air pressure or the pressure of an enclosed vessel. Why are you saying Blood Pressure?
So why not do what was done on the website?
In the end of tutorial the blood pressure is not measured due to tuning
Considering that he failed, is there some reason that you think that the HX710B would be appropriate for this project
I want to make my project as cheaper as it could. I want to try to make business level idea
Well, that leaves me out. I basically don't have the time to do a cost analysis of several different possible designs.
Do you think that there is failure or success in a Research Project? All that are here are the progresses?
I am doing a school project so I decided to make it smaller and cheaper. I am trying to make it cheaper because everyone can buy it
What kind of electronic design experience do you have?
How many and what kind of electronic circuits have you designed?
I am just trying to make my school project. By the way what other pressure sensor i can use
I've never designed a blood pressure machine before, so I can't recommend what sensor to use.
I suggest you do a google search for sphygmomanometer circuit or design
I wrote in post#2, HX710B is not a pressure sensor. It's adc of your sensor module. Sensor is that bigger guy there with "chimney" on your module. You better start studying before building commercial electronics.
Which pressure sensor is best I am so confused now. In the tutorial the guy found value mmHg and also heart beat. Can there is any way to extract blood pressure according the tutorial plote
Yes, if you calibrate the pressure sensor using known pressures as standards. See this tutorial:
