Bluetooth code obd
is it possible to make this work with bluetooth what do you need to change in the code if so?
Yes. Post a rough schematic, not a frizzy picture and links to technical information on the hardware items you will be using. You will need to change the serial output to send the data via bluetooth. Post your updated code following the forum guidelines.
