Bluetooth communication between HC-05 and HC-06
Hi everybody!
I want to build up a bluetooth communication between two arduinos(an Uno and a Mega) I use a HC-05 and HC-06. I connected them to each other by following the instructions of this link:
http://www.martyncurrey.com/connecting-2-arduinos-by-bluetooth-using-a-hc-05-and-a-hc-06-pair-bind-and-link/
Now the two modules are connected to each other (At least the blinks say that).
I want to send anything by the Uno to the Mega, but if i send something and print it to the serial monitor i always get just the number: 128, or a character like this: €.
I think i have the problem in my code, because i bulid the circuit like in the above link.
Here is my code
-For the Uno, with HC-05, which is the master:
#include <SoftwareSerial.h>
SoftwareSerial BTserial(2, 3); // RX | TX
// Connect the HC-05 TX to Arduino pin 2 RX.
// Connect the HC-05 RX to Arduino pin 3 TX through a voltage divider.
char c = ' ';
    // start the serial communication with the host computer
    Serial.println("Arduino with HC-05 is ready");
    // start communication with the HC-05 using 9600
    BTserial.begin(9600);
    Serial.println("BTserial started at 9600");
    BTserial.print('1');
    delay(100);
    Serial.println('1');
-for the Mega with HC-06, which is the slave:
char c = ' ';
    Serial1.begin(9600);
    if (Serial1.available())
        c = Serial1.read();
        Serial.println(c);
I hope you can help.
Thanks!
Are the Mega and the Uno on the same PC?
The Mega is on the Pc, but the uno is not connected the Pc. It has a external power source.
