hello everyone, i'm trying to connect esp32 titigo to odb2 using elmduino library..
i tried some sketch to allow the bluetooth connection, but nothing seems to work.
i tried wiht odbII name and pin 1234 with the elmduino examples but nothing works, so i have found this sketch here on the forum to try connection via odb2 macaddress but i receive this compiling error
#include "BluetoothSerial.h"
#include "ELMduino.h"
BluetoothSerial SerialBT;
#define ELM_PORT SerialBT
#define DEBUG_PORT Serial
//String MACadd = "DC:0D:30:48:8D:60"; //enter the ELM327 MAC address
uint8_t address[6] = {0xEF, 0x30, 0x0D, 0x58, 0x3D, 0xE6}; //enter the ELM327 MAC address after the 0x
ELM327 myELM327;
uint32_t rpm = 0;
#if LED_BUILTIN
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
#endif
DEBUG_PORT.begin(115200);
SerialBT.setPin("1234");
ELM_PORT.begin("ArduHUD", true);
if (!ELM_PORT.connect(address)) //"OBDII" replaced by "address"
DEBUG_PORT.println("Couldn't connect to OBD scanner - Phase 1");
while (1);
if (!myELM327.begin(ELM_PORT))
Serial.println("Couldn't connect to OBD scanner - Phase 2");
while (1);
Serial.println("Connected to ELM327");
float tempRPM = myELM327.rpm();
if (myELM327.status == ELM_SUCCESS)
rpm = (uint32_t)tempRPM;
Serial.print("RPM: "); Serial.println(rpm);
printError();
void printError()
Serial.print("Received: ");
for (byte i = 0; i < myELM327.recBytes; i++)
Serial.write(myELM327.payload[i]);
Serial.println(F("\tELM_SUCCESS"));
else if (myELM327.status == ELM_NO_RESPONSE)
Serial.println(F("\tERROR: ELM_NO_RESPONSE"));
else if (myELM327.status == ELM_BUFFER_OVERFLOW)
Serial.println(F("\tERROR: ELM_BUFFER_OVERFLOW"));
else if (myELM327.status == ELM_UNABLE_TO_CONNECT)
Serial.println(F("\tERROR: ELM_UNABLE_TO_CONNECT"));
else if (myELM327.status == ELM_NO_DATA)
Serial.println(F("\tERROR: ELM_NO_DATA"));
else if (myELM327.status == ELM_STOPPED)
Serial.println(F("\tERROR: ELM_STOPPED"));
else if (myELM327.status == ELM_TIMEOUT)
Serial.println(F("\tERROR: ELM_TIMEOUT"));
Serial.println(F("\tERROR: ELM_GENERAL_ERROR"));
delay(100);
error
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino: In function 'void loop()':
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino:49:16: error: 'class ELM327' has no member named 'status'
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino: In function 'void printError()':
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino:68:16: error: 'class ELM327' has no member named 'status'
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino:70:21: error: 'class ELM327' has no member named 'status'
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino:72:21: error: 'class ELM327' has no member named 'status'
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino:74:21: error: 'class ELM327' has no member named 'status'
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino:76:21: error: 'class ELM327' has no member named 'status'
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino:78:21: error: 'class ELM327' has no member named 'status'
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino:80:21: error: 'class ELM327' has no member named 'status'
/Users/Gianlu/Documents/Arduino/libraries/ELMDuino/examples/ESP32_Bluetooth_Serial/ESP32_Bluetooth_Serial.ino:82:21: error: 'class ELM327' has no member named 'status'
exit status 1
Compilation error: 'class ELM327' has no member named 'status'
