I just got involved with arduino a few days ago and am enjoying learning more about how circuitry works. For my next project, I would like to connect my remote garage door opener to arduino and make it such that I can open and close my garage door opener using arduino code. Later, I intend on implementing this into an app, but what I would like to know just how I should go about setting this up. I have seen tutorials online, but I was hoping to get assistance for my direct project. I have a lift master garage and I will link a picture of the remote opener's circuit below.
Front - IMG_1163.JPG - Google Drive
Back - IMG_1164.JPG - Google Drive
Thank you for your help.
the crude way: check how the button is wired and add an arduino to the original pcb.
As #1, there is usually a manual button somewhere on the unit.
Originally intended for a wired aux button in the garage.
Operate via a set of voltage free relay contacts.
I have this same project working at my house. I use LORA transceivers as opposed to bluetooth--but the concept is the same.
I have my arduino nano output to a 5vdc relay, upon close it closes the contacts that are also connected to the wired remote in the garage (the push button but the door where you can manually open/close the door). Basically that switch momentarily closes--the garage door senses closed circuit and opens or closes the door. My relay is simply in parallel with that switch. Works like a million bucks.
My unit also
- has an ultrasonic distance sensor so the arduino can detect door position open or closed
- unit has a wireless transceiver E44-TTL-100.
- there is a second "base" unit in the house that sends / receives signals from the garage door
- base has a graphic touch screen with open close buttons where i can open / close the door
- base also reports current status of door (no more peeking in garage to see door status)
- base also has wifi and connects to my home internet so I can see door status and open/close from any connected device (computer or phone).
The wifi module works sometimes though--junky unit. Other that that pretty cool. Future aditions will be to connect lights, weather sensors, hotwater tanks temp, and maybe the a/c unit.
Thank you for your detailed explanation of your setup. After further research and reading through the comments on my post, yours included, it seems like I should connect the points the button is connected with to a relay board and then connect that to an arduino uno or something like it which will have a Bluetooth or Lora module connected to it. Then I can code the arduino to perform the desired tasks. Does this seem correct? Thank you.
bensalk:
Common and normally open voltage free contacts on the relay, yes and then arrange the code to only operate the relay on for maybe 1 second and then turn off again.
Perfect! So, I will solder wire to the different contact sides- after reading with multimeter- and then connect to the COM and NO on the relay. Thank you for your help.
