Bluetooth on arduino uno r4 wifi
i saw here Bluetooth LE on UNO R4 WiFi that they are adding initial support for bluetooth on arduino r4 wifi.
do you know if they will add it in the arduino ble library? because in the link it is said to flash the software on the esp32 which I would like to avoid because I have never done it and I don't want to make a mess.
also do you know if it will be possible to use the bluetooth of the arduino r4 wifi to simulate a bluetooth keyboard? (i.e. a bluetooth hid device). if I'm not mistaken the esp 32 mounted above should be able to
Hey will this make Bluetooth work on the Arduino uno r4 wifi? Has anyone got it to work ? Or no one can't use Bluetooth at the moment?
there is a corresponding change in the esp32-s3 firmware. so you would have to build the
fw with the change and update the fw.
maybe just wait for Arduino to release the fw, fiw updater and the library
