Bluetooth problem nodemcu
please help me, library has instaled, esp8266 nodemcu
Arduino:1.8.19 (Windows Store 1.8.57.0) (Windows 10), Płytka:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
sketch_may09a:3:17: error: no matching function for call to 'BluetoothSerial::BluetoothSerial()'
3 | BluetoothSerial SerialBT;
In file included from D:\Dokumenty\Arduino\sketch_may09a\sketch_may09a.ino:1:
D:\Dokumenty\Arduino\libraries\BluetoothSerial\src/BluetoothSerial.h:42:5: note: candidate: 'BluetoothSerial::BluetoothSerial(HardwareSerial&, bool)'
42 | BluetoothSerial(HardwareSerial& serial, bool verbose = true);
D:\Dokumenty\Arduino\libraries\BluetoothSerial\src/BluetoothSerial.h:42:5: note: candidate expects 2 arguments, 0 provided
D:\Dokumenty\Arduino\libraries\BluetoothSerial\src/BluetoothSerial.h:17:7: note: candidate: 'constexpr BluetoothSerial::BluetoothSerial(const BluetoothSerial&)'
17 | class BluetoothSerial {
D:\Dokumenty\Arduino\libraries\BluetoothSerial\src/BluetoothSerial.h:17:7: note: candidate expects 1 argument, 0 provided
D:\Dokumenty\Arduino\libraries\BluetoothSerial\src/BluetoothSerial.h:17:7: note: candidate: 'constexpr BluetoothSerial::BluetoothSerial(BluetoothSerial&&)'
D:\Dokumenty\Arduino\sketch_may09a\sketch_may09a.ino: In function 'void setup()':
sketch_may09a:9:18: error: invalid conversion from 'const char*' to 'int' [-fpermissive]
9 |   SerialBT.begin("ESP32 LED"); // Inicjalizacja komunikacji Bluetooth z nazwą modułu
  |                  const char*
D:\Dokumenty\Arduino\libraries\BluetoothSerial\src/BluetoothSerial.h:51:20: note: initializing argument 1 of 'void BluetoothSerial::begin(int)'
51 | void begin(int baudRate = 9600);
D:\Dokumenty\Arduino\sketch_may09a\sketch_may09a.ino: In function 'void loop()':
sketch_may09a:14:16: error: 'class BluetoothSerial' has no member named 'available'
14 | if (SerialBT.available()) {
sketch_may09a:15:34: error: 'class BluetoothSerial' has no member named 'read'
15 | char receivedChar = SerialBT.read(); // Odczyt danych z modułu Bluetooth
sketch_may09a:19:16: error: 'class BluetoothSerial' has no member named 'println'
19 | SerialBT.println("LED on"); // Wysłanie wiadomości zwrotnej przez Bluetooth
sketch_may09a:22:16: error: 'class BluetoothSerial' has no member named 'println'
22 | SerialBT.println("LED off"); // Wysłanie wiadomości zwrotnej przez Bluetooth
Znaleziono wiele bibliotek w "BluetoothSerial.h"
Wykorzystane: D:\Dokumenty\Arduino\libraries\BluetoothSerial
Niewykorzystane: D:\Dokumenty\Arduino\libraries\BluetoothSerial-1.1.0
exit status 1
Ten raport powinien zawierać więcej informacji jeśli w
File -> Preferencje zostanie włączona opcja "Pokaż
szczegółowe informacje podczas kompilacji"
Welcome to the forum
Your topic has nothing to do with the installation or operation of IDE 1,x so it has been moved to the Programming Qustions category of the forum
Please post your full sketch, using code tags when you do
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
Is the BluetoothSerial library compatible with the ESP8266 or only the ESP32 ?
See arduino-esp32/libraries/BluetoothSerial at master · espressif/arduino-esp32 · GitHub
In fact, can the ESP8266 do Bluetooth at all ?
I think the answer is No and No.
