Bluetooth connection problem with Esp32
Hi, I am new to this. I bought a NodeMCU Esp32, I tried to use the BluetoothSerial example to test it, but it did not connect, the following message appeared in a loop...
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4604
ho 0 tail 12 room 4
load:0x40078000,len:15488
load:0x40080400,len:4
load:0x40080404,len:3180
entry 0x40080805b8
I tried several things like checking if it was the cable (not the problem), I installed the BluetoothSerial.h library, I also installed the CP210x_Universal_Windows_Driver, but none of that worked, the Esp32 does not appear in the application I use (Serial Bluetooth Terminal), I enter Bluetooth in my cell phone but it does not appear in "available devices". I would assume that it is well configured in the monitor uses 115200 baud, finally I tried the types of board raising them by touching the button "BOOT" and then "ON", but it keeps sending me the above message in loop and does not appear the device to connect.
I just need to install some fireware but I did not see in any video or forum to do this for the problem.
It looks like the ESP32 is connected because I tried the Examples>Basics>Blink and it worked.
If someone can help me I would appreciate it, I've been having the same problem for several days without being able to activate the Bluetooth.
The example code is this:
#include <BluetoothSerial.h>
// This example code is in the Public Domain (or CC0 licensed, at your option.)
// By Evandro Copercini - 2018
// This example creates a bridge between Serial and Classical Bluetooth (SPP)
// and also demonstrate that SerialBT have the same functionalities of a normal Serial
// Note: Pairing is authenticated automatically by this device
String device_name= "ESP32-BT-Slave";
// Check if Bluetooth is available
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
// Check Serial Port Profile
#if !defined(CONFIG_BT_SPP_ENABLED)
#error Serial Port Profile for Bluetooth is not available or not enabled. It is only available for the ESP32 chip.
#endif
BluetoothSerial SerialBT;
  SerialBT.begin(device_name);  //Bluetooth device name
  //SerialBT.deleteAllBondedDevices(); // Uncomment this to delete paired devices; Must be called after begin
  Serial.printf("The device with name \"%s\" is started.\nNow you can pair it with Bluetooth!\n", device_name.c_str());
  if (Serial.available()) {
    SerialBT.write(Serial.read());
  if (SerialBT.available()) {
    Serial.write(SerialBT.read());
  delay(20);
Thanks for reading (This message is translated from Spanish to English with a translator I apologize for any inconsistency on my part).
Translated with DeepL.com (free version) :face_exhaling:
IDK.... should you designate the Serial.BT pins
ie: SerialBT.begin(2,3); __- or whatever pins are used !
common use is pin2 & pin3.
ran the code of post 1 on a NodeMCU ESp32 using Tools>Board ESP32 Dev Module and it works OK to my Android phone
Serial monitor displays some text send from the phone
The device with name "ESP32-BT-Slave" is started.
468986hello
Android phone is running Serial Bluetooth App
the code is using Bluetooth Classic - some phones only support BLE
for a BLE UART example try Tools>BLE>UART
running the code it displays
Waiting a client connection to notify...
Received Value: hello
Received Value: bye
using the Android terminal app with a Bluetooth LE device selected
Thanks for the suggestion although I am having trouble using the BLE:
Using ESP32 BLE Arduino library ESP32 with version 1.0.1 in the folder: C:\Usersers Arduino IDE library ESP32 BLE Arduino.
exit status 1
Compilation error: conversion from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to non-scalar type 'String' requested
I've been having the same problem for more than three days, I think I'll leave it, I don't have another esp32 to test. If anyone has any other suggestions I would appreciate it. :sweat_smile:
post the code and the full error message
FQBN: esp32:esp32:nodemcu-32s:EraseFlash=all
Using board 'nodemcu-32s' from platform in folder: C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4
Using core 'esp32' from platform in folder: C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4
cmd /c if exist "C:\\Users\\GUSTAVO\\Documents\\Arduino IDE\\BLE_prueba\\partitions.csv" COPY /y "C:\\Users\\GUSTAVO\\Documents\\Arduino IDE\\BLE_prueba\\partitions.csv" "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\partitions.csv"
cmd /c if not exist "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\partitions.csv" if exist "C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\nodemcu-32s\\partitions.csv" COPY "C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\nodemcu-32s\\partitions.csv" "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\partitions.csv"
cmd /c if not exist "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\partitions.csv" COPY "C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\tools\\partitions\\default.csv" "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\GUSTAVO\\Documents\\Arduino IDE\\BLE_prueba\\bootloader.bin" ( COPY /y "C:\\Users\\GUSTAVO\\Documents\\Arduino IDE\\BLE_prueba\\bootloader.bin" "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\BLE_prueba.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\nodemcu-32s\\bootloader.bin" ( COPY "C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\nodemcu-32s\\bootloader.bin" "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\BLE_prueba.ino.bootloader.bin" ) ELSE ( "C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\BLE_prueba.ino.bootloader.bin" "C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32\\bin\\bootloader_dio_80m.elf" ) )
esptool.py v4.6
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\GUSTAVO\\Documents\\Arduino IDE\\BLE_prueba\\build_opt.h" COPY /y "C:\\Users\\GUSTAVO\\Documents\\Arduino IDE\\BLE_prueba\\build_opt.h" "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\build_opt.h"
cmd /c if not exist "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\build_opt.h" type nul > "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\build_opt.h"
cmd /c type nul > "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts"
Detectando las librerías usadas...
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2\sketch\BLE_prueba.ino.cpp -o nul
Alternativas para BLEDevice.h: [ESP32 BLE Arduino@1.0.1 BLE@3.0.4]
ResolveLibrary(BLEDevice.h)
  -> Candidatos: [ESP32 BLE Arduino@1.0.1 BLE@3.0.4]
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2\sketch\BLE_prueba.ino.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLE2902.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLE2904.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEAddress.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEAdvertisedDevice.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEAdvertising.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEBeacon.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLECharacteristic.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLECharacteristicMap.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEClient.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEDescriptor.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEDescriptorMap.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEDevice.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEEddystoneTLM.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEEddystoneURL.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEExceptions.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEHIDDevice.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLERemoteCharacteristic.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLERemoteDescriptor.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLERemoteService.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEScan.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLESecurity.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEServer.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEService.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEServiceMap.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEUUID.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEUtils.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\BLEValue.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\FreeRTOS.cpp -o nul
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src\GeneralUtils.cpp -o nul
Generating function prototypes...
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2302/bin/xtensa-esp32-elf-g++ -c @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/cpp_flags -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NODEMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/defines -IC:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba -iprefix C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/include/ @C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/flags/includes -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-b6b4727c58\esp32/dio_qspi/include -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\cores\esp32 -IC:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\variants\nodemcu-32s -Ic:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h @C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts C:\Users\GUSTAVO\AppData\Local\Temp\arduino\sketches\7D5BF01CAFDE04D3426BF3874CEBD7B2\sketch\BLE_prueba.ino.cpp -o C:\Users\GUSTAVO\AppData\Local\Temp\3896389241\sketch_merged.cpp
C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\GUSTAVO\AppData\Local\Temp\3896389241\sketch_merged.cpp
Compilando el sketch...
"C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2302/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32/flags/cpp_flags" -w -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_NODEMCU_32S -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NODEMCU_32S\"" "-DARDUINO_VARIANT=\"nodemcu-32s\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:nodemcu-32s:UploadSpeed=115200,FlashFreq=80,DebugLevel=none,EraseFlash=all\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32/flags/defines" "-IC:\\Users\\GUSTAVO\\Documents\\Arduino IDE\\BLE_prueba" -iprefix "C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32/include/" "@C:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32/flags/includes" "-IC:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-b6b4727c58\\esp32/dio_qspi/include" "-IC:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\cores\\esp32" "-IC:\\Users\\GUSTAVO\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.4\\variants\\nodemcu-32s" "-Ic:\\Users\\GUSTAVO\\Documents\\Arduino IDE\\libraries\\ESP32_BLE_Arduino\\src" "@C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2/build_opt.h" "@C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2/file_opts" "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\sketch\\BLE_prueba.ino.cpp" -o "C:\\Users\\GUSTAVO\\AppData\\Local\\Temp\\arduino\\sketches\\7D5BF01CAFDE04D3426BF3874CEBD7B2\\sketch\\BLE_prueba.ino.cpp.o"
In file included from c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src/BLEAdvertising.h:15,
                 from c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src/BLEServer.h:19,
                 from c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src/BLEDevice.h:18,
                 from C:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba\BLE_prueba.ino:1:
c:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino\src/FreeRTOS.h:61:35: error: 'ringbuf_type_t' has not been declared
   61 |         Ringbuffer(size_t length, ringbuf_type_t type = RINGBUF_TYPE_NOSPLIT);
C:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba\BLE_prueba.ino: In function 'void setup()':
C:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba\BLE_prueba.ino:18:3: error: 'pServepr' was not declared in this scope; did you mean 'pServer'?
   18 |   pServepr->setCallbacks(new MyServerCallbacks());
      |   pServer
C:\Users\GUSTAVO\Documents\Arduino IDE\BLE_prueba\BLE_prueba.ino:18:30: error: expected type-specifier before 'MyServerCallbacks'
Se encontraron varias bibliotecas para "BLEDevice.h"
  Usado: C:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino
  No utilizado: C:\Users\GUSTAVO\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.4\libraries\BLE
Usando librería ESP32 BLE Arduino con versión 1.0.1 en la carpeta: C:\Users\GUSTAVO\Documents\Arduino IDE\libraries\ESP32_BLE_Arduino
exit status 1
Compilation error: 'pServepr' was not declared in this scope; did you mean 'pServer'?
This has nothing to do with BLE.
solo use el ejemplo>BLE>UART
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
BLEServer* pServer = NULL;
BLECharacteristic* pCharacteristic = NULL;
bool deviceConnected = false;
uint32_t value = 0;
#define SERVICE_UUID "0000180f-0000-1000-8000-00805f9b34fb"
#define CHARACTERISTIC_UUID "00002a19-0000-1000-8000-00805f9b34fb"
  BLEDevice::init("ESP32_BLE");
  pServer = BLEDevice::createServer();
  BLEService *pService = pServer->createService(SERVICE_UUID);
  pCharacteristic = pService->createCharacteristic(
                      CHARACTERISTIC_UUID,
                      BLECharacteristic::PROPERTY_READ |
                      BLECharacteristic::PROPERTY_WRITE
  pCharacteristic->setValue("Hello World");
  pService->start();
  BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
  pAdvertising->addServiceUUID(SERVICE_UUID);
  pAdvertising->setScanResponse(false);
  pAdvertising->setMinPreferred(0x06);
  pAdvertising->setMinPreferred(0x12);
  BLEDevice::startAdvertising();
  Serial.println("Characteristic defined! Now you can read it in your phone!");
  if (deviceConnected) {
      pCharacteristic->setValue((uint8_t*)&value, 4);
      pCharacteristic->notify();
      value++;
class MyServerCallbacks: public BLEServerCallbacks {
  void onConnect(BLEServer* pServer) {
    deviceConnected = true;
  void onDisconnect(BLEServer* pServer) {
Anyway I just wanted to run the examples>BluetoothSerial>SerialToSerialBT, but as I said before the Esp32 does not appear to connect and puts the message of the first publication in loop, I already tried pressing the BOOT button and ON.
what smartphone are you using? does it support Bluetooth Classic?
I use a "Xiaomi Mi note 10"
The problem might be related to the breaking changes that espressif made to the ESP32-core when moving on to core-version 3.X
install core 2.0.17 and try again
if this does not help Two things do do:
Adjust the Arduino-IDE to print the maximum detailed compiler-log by following this tutorial
Just an hour ago I tested this code
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
unsigned long MyTestTimer = 0;                   // Timer-variables MUST be of type unsigned long
const byte    OnBoard_LED = 2;     // onboard-LEDESP32 / ESP8266
  Serial.println("Setup-Start");
  PrintFileNameDateTime();
//This example code is in the Public Domain (or CC0 licensed, at your option.)
//By Evandro Copercini - 2018
//This example creates a bridge between Serial and Classical Bluetooth (SPP)
//and also demonstrate that SerialBT have the same functionalities of a normal Serial
  SerialBT.begin("ESP32BT-COMPORT"); //Bluetooth device name
  Serial.println("The device started. Name of device is ESP32BT-COMPORT"); //Bluetooth device name
  Serial.println("Now you can pair it with bluetooth!");
  BlinkHeartBeatLED(OnBoard_LED,250);
  if ( TimePeriodIsOver(MyTestTimer,2000) ) {
    SerialBT.println("Hello from the ESP32-serial bluetoth connection");
// helper-functions
void PrintFileNameDateTime() {
  Serial.println( F("Code running comes from file ") );
  Serial.println( F(__FILE__) );
  Serial.print( F("  compiled ") );
  Serial.print( F(__DATE__) );
  Serial.print( F(" ") );
  Serial.println( F(__TIME__) );
// easy to use helper-function for non-blocking timing
// explanation see here
// https://forum.arduino.cc/t/example-code-for-timing-based-on-millis-easier-to-understand-through-the-use-of-example-numbers-avoiding-delay/974017
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - startOfPeriod >= TimePeriod ) {
    // more time than TimePeriod has elapsed since last time if-condition was true
    startOfPeriod = currentMillis; // a new period starts right here so set new starttime
    return true;
  else return false;            // actual TimePeriod is NOT yet over
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
  static unsigned long MyBlinkTimer;
  pinMode(IO_Pin, OUTPUT);
  if ( TimePeriodIsOver(MyBlinkTimer,BlinkPeriod) ) {
    digitalWrite(IO_Pin,!digitalRead(IO_Pin) );
You have to pair your device with the ESP32
and
you have to open the bluetooth-serial connection
only after opening the Comport the bluetooth-connection will be established
i downloaded version 2.0.17 first tried the code you sent
and I got the following message in a loop:
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:13260
load:0x40080400,len:3028
entry 0x40080805e4
Setup-Start
C:\Usersers\GUSTAVO\AppData\Local\Temp\.arduinoIDE-unsaved202476-1832-wjn1hr.ukx2\sketch_aug6a\sketch_aug6a.ino
  compiled Aug 6 2024 16:37:04
Brownout detector was triggered
Then I tried with BluetoothSerial example but it gives the same message, Esp32 does not appear to connect. But thanks for the help, maybe I didn't follow some part correctly.
this looks like a power supply problem
do you have anything else connected to the ESP32?
try a different USB cable and/or USB port
I ran the serialBT code of post 1 OK using Espressif ESP32 core version 3.0.4
I use the PC I have and I don't have another cable at the moment to test. :sweat:
