Bluetooth variable speed control of stepper using Nano + HC05
This is not my first Arduino project, but it's been a few years (mechatronics education). I'm going to attempt to implement a circuit design to remotely control the speed of a Nema 34 stepper. I'm asking if someone with experience using the HC-05 modules can take a look at the wiring diagram before I get started on coding and let me know if there are any obvious issues/mistakes in this circuit. I do not have parts yet (on order...mid next week).
Please make schematics for at least the HC-05 section. Those pictures are not useful for telling. Pin names are interesting but pin positions tell nothing as most helpers don't know all Your circuitry by heart.
I agree the screenshots were not ideal for a wiring diagram. Here is a schematic that may be more useful... for telling.
You have connected 5 volt to Vin. I'm not sure that's good. Check the datasheet for the voltage range.
Also checck the HC-05 datasheet for the current needed. Taking the 5 volt from the Arduino might be good, might be not good.
Applying 220 volt AC to the stepper driver looks like popping it to me.
It is not good. If you have a regulated +5V supply, you can feed that directly into the +5V pin on the Nano. The Vin pin goes to the on board voltage regulator so it needs 6-12V.
Depends on the StepperOnLine driver he is planning to use.
@tjpayne has shown a DM556T with DC input voltage only, and a DM860 which can accept AC voltage input.
Okey but how much of voltage? The datasheet surely tells.
From datasheet:
Input voltage 18-80VAC or 36-110VDC
220V AC is definitely too much.
I had to look up that spec sheet for a Nano. Thank you--Vin takes 6 to 12V. The Nano has a max current draw of 50mA (I'm assuming that's 3.3V, probably 30-40mA for 5V?). The HC-05 has a Vcc input range of 3.3-6V with a working draw of 30mA.
I think I will still pull power into the Nano from a 5V supply, but to the 5V pin. Then I'll power the HC-05 Vcc via 3.3V from the Nano. This should sort out the power issues you pointed out, thoughts?
Nice catch! In the original diagram (from Cirkit) I did use a DM556 driver and hooked it to a 24V supply. In the schematic from EasyEDA I changed to a 220Vac source and the DMA860. I was still trying to determine what I wanted the stepper/driver setup to look like...apologies for the confusion.
Consequently, I will edit the schematic to properly reflect what I Actually decided to do--use a DM2282T from stepperonline which takes a 180-240Vac input. This is so that I could potentially run a Nema34 or 42 stepper with the 8.2A peak current output.
But be aware, that you should not connect it directly to your mains outlet - even if the voltage fits. You need to use a transformer for safety reasons. See datasheet:
Thanks for that reminder! I remember that isolation transformers are generally good practice for AC supply to electronics. Because I'm using mains power, I will search for a 1:1 isolation transformer to add to the circuit.
