Blynk exit status 1, using arduino ide
Greetings, I have an issue regarding compilation of my code. The error message is exit status 1. I want to connect esp32cam with my blynk. I am using Ai Thinker baord. Below is my code.
#include <ESP32QRCodeReader.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// Blynk credentials
#define BLYNK_TEMPLATE_ID "TMPL6bPkPpEMG"
#define BLYNK_TEMPLATE_NAME "Parcel List"
#define BLYNK_AUTH_TOKEN "WFYvhggO_XlLqKK4sp6YU_WwXUn5DArR"
ESP32QRCodeReader reader(CAMERA_MODEL_AI_THINKER);
// WiFi credentials
char ssid[] = "hakeem";
char pass[] = "28092000";
BlynkTimer timer;
const int numLocations = 3;
float datalat = 0;
float datalong = 0;
// Arrays to store parsed latitude and longitude
float latitudes[numLocations];
float longitudes[numLocations];
char latStr[10];
char lonStr[11];
// Constants for Earth's radius and conversion factors
const float EARTH_RADIUS_KM = 6371.0; // Earth's radius in kilometers
const float DEG_TO_RAD_CONV = 0.01745329251; // Degrees to radians conversion factor
// Function to calculate distance between two GPS coordinates using Haversine formula
float haversine(float lat1, float lon1, float lat2, float lon2) {
  // Convert coordinates from degrees to radians
  float latRad1 = lat1 * DEG_TO_RAD_CONV;
  float lonRad1 = lon1 * DEG_TO_RAD_CONV;
  float latRad2 = lat2 * DEG_TO_RAD_CONV;
  float lonRad2 = lon2 * DEG_TO_RAD_CONV;
  // Calculate differences in latitudes and longitudes
  float deltaLat = latRad2 - latRad1;
  float deltaLon = lonRad2 - lonRad1;
  // Haversine formula to calculate distance
  float a = pow(sin(deltaLat / 2), 2) + cos(latRad1) * cos(latRad2) * pow(sin(deltaLon / 2), 2);
  float c = 2 * atan2(sqrt(a), sqrt(1 - a));
  float distance = EARTH_RADIUS_KM * c;
  return distance; // Distance in kilometers
void onQrCodeTask(void *pvParameters) {
  struct QRCodeData qrCodeData;
  while (true) {
    if (reader.receiveQrCode(&qrCodeData, 100)) {
      Serial.println("Found QRCode");
      if (qrCodeData.valid) {
        Serial.print("Payload: ");
        Serial.println((const char *)qrCodeData.payload);
        // Clear any previous location data
        // memset(locationData, 0, sizeof(locationData));
        // Copy the payload into the locationData array
        String locationPayload = (const char *)qrCodeData.payload;
        // Parse the location data
        if (parseLocation(locationPayload, datalat, datalong)) {
          // Convert float values to strings with six decimal places
          dtostrf(datalat, 8, 6, latStr);
          dtostrf(datalong, 9, 6, lonStr);
          Serial.print("Parsed latitude: ");
          Serial.println(latStr);
          Serial.print("Parsed longitude: ");
          Serial.println(lonStr);
          // Send to Blynk Terminal
          Blynk.virtualWrite(V3, "Parsed latitude: ");
          Blynk.virtualWrite(V3, latStr);
          Blynk.virtualWrite(V3, "\nParsed longitude: ");
          Blynk.virtualWrite(V4, lonStr);
          Blynk.virtualWrite(V4, "\n");
          calculation();
          Serial.println("Invalid location format");
          Blynk.virtualWrite(V3, "Invalid location format\n");
        Serial.print("Invalid: ");
        Blynk.virtualWrite(V3, "Invalid: ");
        Blynk.virtualWrite(V3, (const char *)qrCodeData.payload);
        Blynk.virtualWrite(V3, "\n");
    vTaskDelay(100 / portTICK_PERIOD_MS);
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V6)
  // Set incoming value from pin V0 to a variable
  int value = param.asInt();
  // Update state
  Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
  // Change Web Link Button message to "Congratulations!"
  Blynk.setProperty(V5, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
  Blynk.setProperty(V5, "onImageUrl",  "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
  Blynk.setProperty(V5, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
  // You can send any value at any time.
  // Please don't send more than 10 values per second.
  Blynk.virtualWrite(V2, millis() / 1000);
  reader.setup();
  Serial.println("Setup QRCode Reader");
  reader.beginOnCore(1);
  Serial.println("Begin on Core 1");
  xTaskCreate(onQrCodeTask, "onQrCode", 4 * 1024, NULL, 4, NULL);
  // Blynk setup
  Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass);
  timer.setInterval(1000L, myTimerEvent);
  Blynk.run();
  timer.run();
void calculation() {
  // Fixed coordinates for the central location (latitude and longitude in degrees)
  float lat1 = 2.9622653; // Central location latitude
  float lon1 = 101.7549858; // Central location longitude
  // Example coordinates for other locations (latitude and longitude in degrees)
  float lat2 = atof(latStr);
  float lon2 = atof(lonStr);
  // Calculate distances between the central location and other locations using Haversine formula
  float distance1_2 = haversine(lat1, lon1, lat2, lon2);
  // Print distances to serial monitor for debugging
  Serial.print("Distance between Central Location and Waypoint 1: ");
  Serial.print(distance1_2);
  Serial.println(" kilometers");
  Blynk.virtualWrite(V0, distance1_2);
  delay(1000); // Delay for 1 second before repeating the calculation
// Function to parse location data in the format "latitude,longitude"
bool parseLocation(String location, float &latitude, float &longitude) {
  int commaIndex = location.indexOf(',');
  if (commaIndex != -1) {
    latitude = location.substring(0, commaIndex).toFloat();
    longitude = location.substring(commaIndex + 1).toFloat();
    return true;
    return false;
No, that's not the error message. Its just an information message to tell you the upload could not be done because the code would not compile.
The real error messages will be above the "exit status 1" message. Copy the whole set of messages and post them between code tags.
error: #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
39 | #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME"
exit status 1
Compilation error: exit status 1
#include <WiFi.h>
// WiFi credentials
BlynkTimer timer;
float datalat = 0;
float datalong = 0;
char latStr[10];
char lonStr[11];
  while (true) {
          calculation();
BLYNK_WRITE(V6)
  // Update state
BLYNK_CONNECTED()
void myTimerEvent()
  reader.setup();
  // Blynk setup
  Blynk.run();
  timer.run();
    return true;
    return false;
Based on the code there's 2 error message dsiplayed "error: 'parseLocation' was not declared in this scope
71 | if (parseLocation(locationPayload, datalat, datalong)) {" and "error: expected '}' at end of input
137 | Serial.println("Setup QRCode Reader");"
But the errors from post #3 are fixed, yes?
I will ask you for a second time. Please post error messages in code tags.
Move all definitions of functions to be before those functions are used/called. This is the normal rule. The Arduino IDE allows you break this rule, but not always. Other IDE will not let you break this rule at all. So it is best to follow this rule.
Also please use Auto-Format from the Tools menu. It may help solve one of those errors.
I've done the code and it works. It seems I have missed certain part of the coding while copying from my other arduino ide. Thanks PaulRB for the insights and assistance! I pray that you'll be in god's blessing.
