So my code kept saying that it has error "exit status 1
Compilation error: exit status 1"
here's my code ![]()
#include <Arduino.h>
#include <SPI.h>
#include <RadioLib.h> // RadioLib CC1101 driver
#include <NimBLEDevice.h> // NimBLE for BLE peripheral
// ---------- HW pin definitions (ปรับได้ตามบอร์ดจริง) ----------
#define PIN_SPI_CS 10 // CS for CC1101
#define PIN_GDO0 3 // GDO0 from CC1101 -> IRQ
#define PIN_ADC 0 // ADC1_CH0 (GPIO0) -> MPX5700AP output
// ---------- CC1101 (RadioLib) object ----------
SX1278 rfModule; // placeholder to avoid compile error if SX1278 referenced; we will create CC1101 below
// RadioLib has a CC1101 class named "CC1101" or "CC1101" depending on version.
// If your RadioLib version exposes CC1101 as "CC1101", use that class instead:
CC1101 cc1101(PIN_SPI_CS, PIN_GDO0); // CS, GDO0
// ---------- BLE definitions ----------
#define BLE_DEVICE_NAME "ESP32-C3-Tire"
#define BLE_SERVICE_UUID "12345678-1234-1234-1234-1234567890ab"
#define BLE_CHAR_PRESSURE_UUID "abcd1234-5678-90ab-cdef-1234567890ab"
NimBLEServer* pServer = nullptr;
NimBLECharacteristic* pPressureChar = nullptr;
bool deviceConnected = false;
class ServerCallbacks : public NimBLEServerCallbacks
void onConnect(NimBLEServer* pServer)
deviceConnected = true;
void onDisconnect(NimBLEServer* pServer)
// ---------- helper: read MPX5700AP via ADC ----------
float readPressure_kPa()
// MPX5700AP: output ~ Vout = Vs * (0.2 * (P/700) + offset) depending on wiring.
// This function returns raw voltage and user converts to kPa based on sensor wiring/calibration.
const float ADC_REF = 3.3f; // ADC reference (V)
const int ADC_MAX = 4095; // 12-bit ADC
int raw = analogRead(PIN_ADC);
float voltage = (raw * ADC_REF) / ADC_MAX;
// User must convert voltage -> pressure using sensor transfer function and supply voltage.
// Example placeholder conversion (ADJUST with calibration):
// MPX5700AP typical sensitivity ~ 26.6 mV/kPa at Vs=10V ; if using supply and amplifier different, calibrate.
float pressure_kPa = voltage; // placeholder, return voltage for now
return pressure_kPa;
// ---------- CC1101 receive callback via interrupt ----------
volatile bool cc1101PacketReady = false;
void IRAM_ATTR cc1101ISR()
cc1101PacketReady = true;
void setupCC1101()
// initialize SPI if necessary (RadioLib handles SPI)
SPI.begin(); // use default pins mapped earlier; adjust if needed
// Initialize CC1101
int state = cc1101.begin();
if (state != RADIOLIB_ERR_NONE)
// init failed, blink LED or serial error
Serial.print("CC1101 init failed, code: ");
Serial.println(state);
// don't halt; continue to allow BLE for debugging
Serial.println("CC1101 init OK");
// Example configuration: set frequency, modulation, datarate
// Adjust parameters to match transmitter
cc1101.setFrequency(433.92); // MHz, change to 868 or 915 as needed
cc1101.setBitRate(4800); // bps
cc1101.setModulation(2); // 2 = GFSK in some RadioLib versions; check docs
cc1101.setOutputPower(8); // dBm, adjust
// attach interrupt on GDO0 for packet received (falling/rising depends on GDO mapping)
pinMode(PIN_GDO0, INPUT);
attachInterrupt(digitalPinToInterrupt(PIN_GDO0), cc1101ISR, RISING);
// Put CC1101 in RX mode
cc1101.receive();
void setupBLE()
NimBLEDevice::init(BLE_DEVICE_NAME);
pServer = NimBLEDevice::createServer();
pServer->setCallbacks(new ServerCallbacks());
NimBLEService* pService = pServer->createService(BLE_SERVICE_UUID);
pPressureChar = pService->createCharacteristic(
BLE_CHAR_PRESSURE_UUID,
NIMBLE_PROPERTY::READ | NIMBLE_PROPERTY::NOTIFY);
pPressureChar->setValue("0.00");
pService->start();
NimBLEAdvertising* pAdv = NimBLEDevice::getAdvertising();
pAdv->addServiceUUID(BLE_SERVICE_UUID);
pAdv->start();
Serial.println("BLE advertising started");
delay(100);
// ADC config
analogReadResolution(12); // 12-bit ADC (0-4095)
// Optionally set attenuation depending on expected voltage
analogSetPinAttenuation(PIN_ADC, ADC_11db); // supports up to ~3.3V reading better
setupBLE();
setupCC1101();
Serial.println("Setup complete");
// Periodically read sensor and send BLE notify
static unsigned long lastSensorMs = 0;
const unsigned long SENSOR_INTERVAL = 5000; // ms
if (millis() - lastSensorMs >= SENSOR_INTERVAL)
lastSensorMs = millis();
float p = readPressure_kPa(); // placeholder: returns voltage; calibrate to kPa
char buf[32];
// format as string (pressure or voltage)
snprintf(buf, sizeof(buf), "%.3f", p);
pPressureChar->setValue(buf);
if (deviceConnected)
pPressureChar->notify(); // send notify to connected device
Serial.print("Sensor: ");
Serial.println(buf);
// Handle CC1101 received packet
if (cc1101PacketReady)
// read raw packet
String rcv;
int state = cc1101.readData(rcv); // RadioLib readData overload returns string
if (state == RADIOLIB_ERR_NONE)
Serial.print("RF RX: ");
Serial.println(rcv);
// optionally parse payload, e.g., "ID:123;P:45.6"
// and forward via BLE characteristic or update state
// Example: send received payload as BLE notify as well
pPressureChar->setValue(rcv.c_str());
else if (state == RADIOLIB_ERR_RX_TIMEOUT)
// no data
Serial.print("CC1101 read error: ");
// re-enter receive mode
cc1101.receive();
// NimBLE background processing
NimBLEDevice::run();
I tried some ways that claimed to fix the problem but that never work like I try adding void 'setup () {
but it doesn't work
