Hey Guys,
I want to use the Arduino Mega2560 to read Sensor data from the BME680
But however I connect it, it won't get recognized.
First I tried I2C:
VCC and GND from Sensor to 3.3V and GND on the Arduino
SCL to dedicated PIN 21
SDA to dedicated PIN 20
I used the bme680test.ino from adafruit (in the attachments) for testing but it just says: Could not find a valid BME680 sensor, check wiring!
I also tried the i2c_scanner.ino (also in attachments), a test file from the mega2560 library. Same problem here, "No I2C devices found".
Next, I tried using SPI (which already worked for an SD-Card reader I used with this board):
Following the pinout from the homepage (SPI) and using additional info for connection from here, I connected the Sensor like follows:
SCL to SCK pin 52
SDA (which I guess is same as SDI) to MOSI pin 51
SD0 to MISO pin 50
CS to pin 53
which should be the hardware SPI config, still no sensor found. The exact same happens when changing to software SPI with the mentioned pins...
Do you guys have any clue why this setup is not working with the sensor? I triple check the wiring and when connecting the SD card reader SPI is working just fine...
I am grateful for any help ![]()
i2c_scanner.ino (2.11 KB)
bme680test.ino (2.26 KB)
