BMI323 Sensor With I2C Kalman Filter
Hello,
I am have a project that measures the golf club speed. I am using BMI323 Bosch IMU sensor and I need to make a gravity filter. This is my source code I am doing this project on esp32 that's why I am using arduino IDE. I searched online and find the kalman filter. Bu t I don't understand clearly. Could anyone help me to make a kalman filter for gravitation or any other thing that I can do?
This is my code so far:
#define INC_ADDRESS 0x69
#define ACC_CONF  0x20  //Page 91
#define GYR_CONF  0x21  //Page 93
#define CMD       0x7E  //Page 65
int16_t  x, y, z;
int16_t  gyro_x, gyro_y, gyro_z;
float accelX_m_s2 , accelY_m_s2, accelZ_m_s2;
void setup(void) {
  //Accelerometer
  Wire.begin(7,9);
  Wire.setClock(400000);      // I2C Fast Mode (400kHz)
  softReset();
   * Acc_Conf P.91
   * mode:        0x7000  -> High
   * average:     0x0000  -> No
   * filtering:   0x0080  -> ODR/4
   * range:       0x0000  -> 2G
   * ODR:         0x000B  -> 800Hz
   * Total:       0x708B
  writeRegister16(ACC_CONF,0x753D);//Setting accelerometer
   * Gyr_Conf P.93
   * range:       0x0000  -> 125kdps
   * Total:       0x708B
  writeRegister16(GYR_CONF,0x758D);//Setting gyroscope
void softReset(){
  writeRegister16(CMD, 0xDEAF);
  delay(50);
  if(readRegister16(0x02) == 0x00) {
    //Read ChipID
    readAllAccel();             // read all accelerometer/gyroscope/temperature data
    Serial.print("X: ");
    Serial.print(accelX_m_s2);
    Serial.print("Y: ");
    Serial.print(accelY_m_s2);
    Serial.print("Z: ");
    Serial.println(accelZ_m_s2);
//Write data in 16 bits
void writeRegister16(uint16_t reg, uint16_t value) {
  Wire.beginTransmission(INC_ADDRESS);
  Wire.write(reg);
  //Low
  Wire.write((uint16_t)value & 0xff);
  //High
  Wire.write((uint16_t)value >> 8);
  Wire.endTransmission();
//Read data in 16 bits
uint16_t readRegister16(uint8_t reg) {
  Wire.write(reg);
  Wire.endTransmission(false);
  int n = Wire.requestFrom(INC_ADDRESS, 4);
  uint16_t data[4];
  int i =0;
  while(Wire.available()){
    data[i] = Wire.read();
    i++;
  return (data[3]   | data[2] << 8);
//Read all axis
void readAllAccel() {
  Wire.write(0x03);
  Wire.requestFrom(INC_ADDRESS, 14);
  int16_t data[14];
  int i =0;
    i++;
  //Offset = 2 because the 2 first bytes are dummy (useless)
  int offset = 2;
  x =             (data[offset + 0]        | (int16_t )data[offset + 1] << 8);  //0x03
  y =             (data[offset + 2]        | (int16_t )data[offset + 3] << 8);  //0x04
  z =             (data[offset + 4]        | (int16_t )data[offset + 5] << 8);  //0x05
  gyro_x =        (data[offset + 6]        | (int16_t )data[offset + 7] << 8);  //0x03
  gyro_y =        (data[offset + 8]        | (int16_t )data[offset + 9] << 8);  //0x04
  gyro_z =        (data[offset + 10]       | (int16_t )data[offset + 11] << 8);  //0x05
  accelX_m_s2 = lsbToM2S(x);
  accelY_m_s2 = lsbToM2S(y);
  accelZ_m_s2 = lsbToM2S(z);
float lsbToM2S(int16_t rawData) {
    // Sensitivity for the ±8g range is typically 4096 LSB/g
    const float sensitivity = 2048.0;
    // Convert g to m/s² using the standard Earth gravitational acceleration 9.81 m/s²
    const float gToM2S = 9.80665;
    // Calculate and return the acceleration in m/s²
    return (rawData / sensitivity) * gToM2S;
This is my output.
X: 0.03Y: -0.24Z: 9.73
X: 0.01Y: -0.32Z: 9.65
X: 0.10Y: -0.31Z: 9.68
X: 0.03Y: -0.29Z: 9.68
X: 0.02Y: -0.26Z: 9.68
X: 0.03Y: -0.31Z: 9.72
X: 0.09Y: -0.31Z: 9.77
These values are type of m/s^2.
You can't, with just that 6DOF sensor. To correctly subtract the gravity vector, you must know the 3D orientation very accurately.
I found your github repo how can't I filter the gravity. Could you explain it to me?
This blog post explains the major part of the problem: https://web.archive.org/web/20180112063505/http://www.chrobotics.com/library/accel-position-velocity
