How do i get the float in bmp280 to read the current pressure reading. it keeps defaulting to 1013.25?
what host microcontroller are you using?
what library?
how is the BMP280 connected? upload a schematic?
upload your code (using code tags < code >
Try this sketch: (I2C Communication)
#include <Wire.h>
#include "BlueDot_BME280.h"
BlueDot_BME280 bme;
int bmeDetected = 0; //Checks if Sensor 1 is available
Serial.println(F("Basic Weather Station"));
bme.parameter.communication = 0; //I2C communication for Sensor 1 (bme1)
bme.parameter.I2CAddress = 0x76; //I2C Address for Sensor 1 (bme1)
bme.parameter.sensorMode = 0b11; //Setup Sensor mode for Sensor 1
bme.parameter.IIRfilter = 0b100; //IIR Filter for Sensor 1
bme.parameter.humidOversampling = 0b101; //Humidity Oversampling for Sensor 1
bme.parameter.tempOversampling = 0b101; //Temperature Oversampling for Sensor 1
bme.parameter.pressOversampling = 0b101; //Pressure Oversampling for Sensor 1
bme.parameter.pressureSeaLevel = 1013.25; //default value of 1013.25 hPa (Sensor 1)
bme.parameter.tempOutsideCelsius = 15; //default value of 15°C
if (bme.init() != 0x60)
Serial.println(F("Ops! First BME280 Sensor not found!"));
bmeDetected = 0;
while (1); //wait for ever
Serial.println(F("First BME280 Sensor detected!"));
bmeDetected = 1;
Serial.print("Temperature Sensor [°C]: ");
float bmeTemp = bme.readTempC();
Serial.println(bmeTemp, 2);
Serial.print("Humidity Sensor [%]: ");
float bmeHumid = bme.readHumidity();
Serial.println(bmeHumid, 2);
Serial.print("Pressure Sensor [hPa]: ");
float bmePress = bme.readPressure();
Serial.println(bmePress, 2);
Serial.print("Altitude Sensor [m]: ");
float bmeAlt = bme.readAltitudeMeter();
Serial.println(bmeAlt, 2);
Serial.println("****************************************");
delay(3000); //test interval
