Bmp280 - variometr
Hi. I try will make variometr from this webside :How to make a Arduino variometer for paragliding | Hackaday.io <toneAC.h>
Sketch loaded normal to ending but buzzer working once: when ending load sketch or when switchon pwoer to arudino .When I move sensor baro to up or to down silence. :frowning: Please help me :slight_smile:
Hardware connections:
- (GND) to GND
+ (VDD) to 3.3V
SCL to A5
SDA to A4
D9 and D10 to the Piezo Buzzer ( see toneAC.h )
#define NUM_PRESSURES 64
#define NUM_TOTALS 16
uint32_t pressure[NUM_PRESSURES];
uint32_t old_total[NUM_TOTALS];
int pressure_index = 0;
int total_index = 0;
uint32_t total;
int current_tone = 0;
int beep_time = 0;
// play start sound
  toneAC(388, 4);
  delay(70);
  toneAC(0);
  delay(30);
  toneAC(590, 4);
  delay(70);
  mySensor.begin();
  uint32_t p = mySensor.readPressure();
  total = p*NUM_PRESSURES;
  for(int i = 0; i<NUM_PRESSURES; i++)
    pressure[i] = p;
  for(int i = 0; i<NUM_TOTALS; i++)
    old_total[i] = total;
  toneAC(0);
void loop(){
    total -= pressure[pressure_index];
    pressure[pressure_index] = mySensor.readPressure();
    total += pressure[pressure_index];
    int32_t rate = total - old_total[total_index];
    float frate = (float)rate;
    frate = 0.0;
    old_total[total_index] = total;
    pressure_index++;
    total_index++;
    if(pressure_index >= NUM_PRESSURES)pressure_index = 0;
    if(total_index >= NUM_TOTALS)total_index = 0;
    if(rate < -200){
      if(beep_time <5)
        toneAC(500 - rate);
        toneAC(0);
    else if(rate > 200)
      float f = 100.0 + 40000.0 * 1.0/((float)rate);
      toneAC((int)f);
      toneAC(0);
    beep_time++;
    if(beep_time >= 10)beep_time = 0;
How far up/down did you move the barometer? The datasheet seems to say +/-1m resolution... I assume "m" is "meter."
relative accuracy is ±0.12 hPa, which is equivalent to ±1 m difference in altitude.
That web site author doesn't know about the human body or the inner ear.
we don’t have a dedicated sense to 3D motion
Thank you, I'll check bigger move, beyond 1m :slight_smile: and send info with results
You seem to have some code missing
#include <toneAC.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
Adafruit_BMP085 mySensor;  // create sensor object called mySensor
- (GND) to GND
+ (VDD) to 3.3V
SCL to A5
SDA to A4
also - do you need to modify this to use a bmp280?
My page here shows some tests I made in how best to connect up the bmp280
