hello friends I saw a video about a boost gauge on YouTube and decided to make the same device. The scheme is simple - arduino nano, 1.3” oled display, bmp085 / in my case bmp180/ and pressure sensor mpx4250 / 2.5 bar / I will try to upload the code that is in the description of the video. the problem is the following - according to the way the calibration is described in the code, when the boost meter is attached to the car and the engine is running, the display shows -0.9/-1.0 bar vacuum, which is impossible. when I checked with car diagnostics, it uses -0.35 bar vacuum. To be sure I checked what my lpg ecu was showing too - the readings were the same -0.35 bar vacuum. I doubted the correct operation of the sensor and therefore tried with another / I took the voltage from its specification / mpx5700, but the result was the same. I also tried with a third sensor / BMW original / - the readings were again the same.Can somebody help me make this boostmeter work properly ? Here is a link to the video https://youtu.be/dPYfYAu3kfI?si=tykQVdrlKphNA8ZZ
// Created by Steven Marshall
// Created 23/03/2020
// v1.0.3-beta.1.0
// https://github.com/smarshall-rightside/Project_Power/
// Licensed for non-commercial use ONLY
// Do not remove this header
#include <Arduino.h>
#include <U8g2lib.h>
#include <SPI.h>
#include <Wire.h>
U8G2_SH1106_128X64_NONAME_1_HW_I2C u8g2(U8G2_R2);
unsigned long startMillis;
unsigned long currentMillis;
unsigned long time_passed;
unsigned long lastReset;
const unsigned long period = 50;
const int sensorHistoryLength = 128;
int sensorHistory[sensorHistoryLength];
int sensorHistoryPos = sensorHistoryLength - 1;
int boostPressure;
int boostMax = 0;
int BoostMaxTop = 0;
int boostMin = 0;
float inbar;
float maxinbar;
void setup(void) {
u8g2.begin();
startMillis = millis();
time_passed = millis();
void loop(void) {
// Only read from the sensors every 50 ms
currentMillis = millis();
if (currentMillis - startMillis >= period) {
readSensorData();
startMillis = currentMillis;
// Set Max Boost Value
if (boostPressure >= BoostMaxTop)
BoostMaxTop = boostPressure;
else if (boostPressure < BoostMaxTop)
if (millis() - lastReset > 5000) {
lastReset += 5000;
time_passed = 0;
u8g2.firstPage();
do {
// Draw current pressure
u8g2.setFont(u8g2_font_fub20_tf);
// Change PSI to BAR
inbar = boostPressure / 100;
char cstd[6];
dtostrf((float)inbar / 14.504, 1, 1, cstd);
u8g2.drawStr(0, 20, cstd);
// Draw boost text
// If statment fixes Bug #1
if (boostPressure >=0)
u8g2.setFont(u8g2_font_helvR08_tf);
u8g2.drawStr(40, 20, "BOOST");
else if (boostPressure < 0)
u8g2.drawStr(50, 20, "VAC");
// Draw boost text
if (boostPressure >= 3500)
u8g2.setFont(u8g2_font_fub11_tf);
u8g2.drawStr(40, 10, "MAX");
else if (boostPressure < 3500)
u8g2.drawStr(40, 10, "");
// Draw max pressure
maxinbar = BoostMaxTop / 100;
char csta[6];
dtostrf((float)maxinbar / 14.504, 1, 1, csta);
int yPos = u8g2.getStrWidth(csta);
u8g2.drawStr(128 - yPos, 11, csta);
drawBarGraph(0, 22, 128, 8);
drawGraph(0, 32, 128, 31);
} while ( u8g2.nextPage() );
float normaliseSensorData(int m) {
Scale the sensor reading into range
m = measurement to be scaled
rmin = minimum of the range of the measurement
rmax = maximum of the range of the measurement
tmin = minimum of the range of the desired target scaling
tmax = maximum of the range of the desired target scaling
normalisedValue = ((m − rmin) / (rmax − rmin)) * (tmax − tmin) + tmin
https://stats.stackexchange.com/a/281164
Sensor voltage ranges from 0.5v to 4.5v, converted to analogRead values (0 min, 1023 max) that's 102 to 921. Times the voltage by 204.66
rmin = 102
rmax = 921
Sensor reads from 0 to 50psi
tmin = 0
tmax = 5000
normalisedValue = ((m − 102) / (921 − 102)) * (5000 − 0) + 0
normalisedValue = ((m − 102) / 819) * 5000
normalisedValue = (m − 102) / 0.1638
return (m - 102) / 0.1638;
void readSensorData(void) {
float absolutePressure = normaliseSensorData(analogRead(A0));
// Subtract 14.7 psi == pressure at sea level
// Additional 2.57psi subtracted as boost was showing 2.57 with engine off
boostPressure = absolutePressure - 1727;
// Update max and min
if (boostPressure > boostMax) boostMax = boostPressure;
if (boostPressure < boostMin) boostMin = boostPressure;
// Log the history
addSensorHistory(boostPressure);
void addSensorHistory(int val) {
sensorHistory[sensorHistoryPos] = val;
sensorHistoryPos--;
if (sensorHistoryPos < 0) sensorHistoryPos = sensorHistoryLength - 1;
int getSensorHistory(int index) {
index += sensorHistoryPos;
if (index >= sensorHistoryLength) index = index - sensorHistoryLength;
return sensorHistory[index];
// Display functions
void drawGraph(int x, int y, int len, int height) {
// Draw the lines
drawHorizontalDottedLine(x, y, len);
drawHorizontalDottedLine(x, y + height, len);
//var absMin = Math.abs(boostMin);
int absMin = abs(boostMin);
int range = absMin + boostMax;
// Draw 0 line
int zeroYPos = mapValueToYPos(absMin, range, y, height);
drawHorizontalDottedLine(x, zeroYPos, len);
// Draw the graph line
for (int i = 0; i < 128; i++) {
// Scale the values so that the min is always 0
int valueY = getSensorHistory(i) + absMin;
// Calculate the coordinants
int yPos = mapValueToYPos(valueY, range, y, height);
int xPos = len - i;
if (yPos < zeroYPos) {
// Point is above zero line, fill in space under graph
u8g2.drawVLine(xPos, yPos, zeroYPos + 1 - yPos);
// Point is below zero line, draw graph line without filling in
u8g2.drawPixel(xPos, yPos);
void drawBarGraph(int x, int y, int len, int height) {
if (boostPressure > 0) {
// Draw the pressure bar behind the graph
int barLength = ((float)boostPressure / boostMax) * len;
u8g2.setDrawColor(2);
u8g2.drawBox(x, y, barLength, height);
u8g2.setDrawColor(1);
// Maps a value to a y height
int mapValueToYPos(int val, int range, int y, int height) {
float valueY = ((float)val / range) * height;
return y + height - (int)valueY;
void drawHorizontalDottedLine(int x, int y, int len) {
for (int i = 0; i < len; i++) {
if (!(i % 4)) u8g2.drawPixel(x + i, y);
