Hi, I am using BNO055 for angular velocity calculation. I am new to Arduino and from a different field but I need to understand the output so that I may translate it into my field accurately. Someone helps to fetch angular velocity through the following lines of code. Now I think the angular velocity is in rad/sec (not confirmed) but I want it in deg/sec.
So my question is the angular velocity in Rad/sec when using the Adafruit library? if yes then how to convert to deg/sec?
sensors_event_t gyroEvent;
bno.getEvent(&gyroEvent, Adafruit_BNO055::VECTOR_GYROSCOPE);
Serial.print("Gyroscope (Angular Velocity) X: ");
Serial.print(gyroEvent.gyro.x, 4);
Serial.print("\tY: ");
Serial.print(gyroEvent.gyro.y, 4);
Serial.print("\tZ: ");
Serial.print(gyroEvent.gyro.z, 4);
Serial.println("");
