Hi.
I have a BNO 055 accelerometer used to collect linear acceleration data for a project of mine. Here is the code, mostly taken from the sample library:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
/* This driver reads raw data from the BNO055
Connections
Connect SCL to analog 5
Connect SDA to analog 4
Connect VDD to 3.3V DC
Connect GROUND to common ground
History
2015/MAR/03 - First release (KTOWN)
/* Set the delay between fresh samples */
#define BNO055_SAMPLERATE_DELAY_MS (20)
Adafruit_BNO055 bno = Adafruit_BNO055();
Arduino setup function (automatically called at startup)
void setup(void)
Serial.println("Orientation Sensor Raw Data Test"); Serial.println("");
/* Initialise the sensor */
if(!bno.begin())
/* There was a problem detecting the BNO055 ... check your connections */
Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
while(1);
/* Display the current temperature */
int8_t temp = bno.getTemp();
Serial.print("Current Temperature: ");
Serial.print(temp);
Serial.println(" C");
Serial.println("");
bno.setExtCrystalUse(true);
Serial.println("Calibration status values: 0=uncalibrated, 3=fully calibrated");
Arduino loop function, called once 'setup' is complete (your own code
should go here)
void loop(void)
// Possible vector values can be:
// - VECTOR_ACCELEROMETER - m/s^2
// - VECTOR_MAGNETOMETER - uT
// - VECTOR_GYROSCOPE - rad/s
// - VECTOR_EULER - degrees
// - VECTOR_LINEARACCEL - m/s^2
// - VECTOR_GRAVITY - m/s^2
imu::Vector<3> euler = bno.getVector(Adafruit_BNO055::VECTOR_GRAVITY);
imu::Vector<3> euler2 = bno.getVector(Adafruit_BNO055::VECTOR_EULER);
/* Display the floating point data */
Serial.print("X: ");
Serial.print(euler.x());
Serial.print(" Y: ");
Serial.print(euler.y());
Serial.print(" Z: ");
Serial.print(euler.z());
Serial.print(" ");
Serial.print(millis());
Serial.println("\t\t");
//Serial.print("\t\t");
// Serial.print("X: ");
// Serial.print(euler2.x());
// Serial.print(" Y: ");
// Serial.print(euler2.y());
// Serial.print(" Z: ");
// Serial.print(euler2.z());
// Serial.print(" ");
// Serial.print(millis());
// Serial.println("\t\t");
// Quaternion data
imu::Quaternion quat = bno.getQuat();
Serial.print("qW: ");
Serial.print(quat.w(), 4);
Serial.print(" qX: ");
Serial.print(quat.y(), 4);
Serial.print(" qY: ");
Serial.print(quat.x(), 4);
Serial.print(" qZ: ");
Serial.print(quat.z(), 4);
/* Display calibration status for each sensor. */
//uint8_t system, gyro, accel, mag = 0;
// bno.getCalibration(&system, &gyro, &accel, &mag);
// Serial.print("CALIBRATION: Sys=");
// Serial.print(system, DEC);
// Serial.print(" Gyro=");
// Serial.print(gyro, DEC);
// Serial.print(" Accel=");
// Serial.print(accel, DEC);
// Serial.print(" Mag=");
// Serial.println(mag, DEC);
// delay(BNO055_SAMPLERATE_DELAY_MS);
The problem is, because I integrate this data numerically, twice, to obtain displacement data I need to make sure it is accurate. The acceleration values are OK for my testing but the delta T is not constant and that’s generating huge errors because I continuously integrate. For example here is a sample set of data
X: 0.94 Y: 0.14 Z: -9.75 583048
X: 0.94 Y: 0.14 Z: -9.75 583084
X: 0.94 Y: 0.14 Z: -9.75 583120
X: 0.94 Y: 0.14 Z: -9.75 583156
X: 0.94 Y: 0.14 Z: -9.75 583193
X: 0.94 Y: 0.14 Z: -9.75 583230
the delta T’s between the readings are (in ms) 36, 36, 36, 37, 37. I mean the variation is usually only +/- 1 but it’s significant enough to affect my results especially over a very long time.
What causes this error and how can I mitigate it? I am assuming it is something to do with the serial transmission but I’m not sure. I had the same problem with my LSM9DS0 accelerometer and the sample rates are fixed.
