Boards package in v1.8.19
If I download v1.8.19 from Arduino, will it come with the latest boards package already installed?
If I have to download the latest boards package, is the original boards package in 1.8.19 deleted, or can it be deleted, to recover the space?
As IDE 1.x is not being updated, nor has it been for some time, I would expect it to come with the built in boards packages as at the time that development was frozen. This relates only to Arduino boards packages. No third party packages such as ESP etc are included in the download
The IDE 2.x download does not include any boards packages but they are downloaded and installed when the IDE is first run and taht does include ESP32 packages
As a matter of interest, why do you want to use IDE 1.x rather than 2.x ?
I think you don't need to update included board packages.
It is generally not good idea to update working packages without specific needs.
Hi @ShermanP.
No. The Arduino IDE 1.8.19 installation includes a bundled copy of version 1.8.3 of the "Arduino AVR Boards" platform. The latest version of that platform is 1.8.6.
You can see the changes that were made to the platform between those two versions here:
"Arduino AVR Boards" is the only platform bundled with the Arduino IDE installation. All other platforms must be installed on demand by the user.
No.
I believe so. Give it a try. If you encounter a problem after that, just restore it.
I've always been partial to the portable installation of v1.x, and was told that isn't an option with v2. Also, I continue to see a number of issues reported here with whatever the latest version of v2 is at the moment, and I tend to steer clear of things that complicate my life, particularly since what I'm using now (actually v1.8.8) works quite well. But I thought if 19 came with the latest boards package, it might be worthwhile upgrading to that.
If all you want is the latest platform, just use Boards Manager to update to the latest version. You might even have already done that.
However, I do think it is worthwhile to update to 1.8.19. There was quite a lot of work done between 1.8.8 and 1.8.19, and that included removal of the Log4j Java package due to a critical security vulnerability in that package (it should be noted that there was never any evidence that the vulnerability in the package actually resulted in a vulnerability in Arduino IDE, but even so it is really not the sort of thing you want to have running on your computer). I'm not aware of any significant regressions or usability changes that occurred between 1.8.8 and 1.8.19.
Ok, so aside from the issue of the boards update, I could in theory simply move the Portable folder to the 1.8.19 folder - before booting it. Portable includes whatever the latest ESP8266 package was at the time. And it should all work. Right?
That is correct.
That certainly seems like it ought to work, but I just recently tried exactly that going from 1.8.13 to 1.8.19, and the 1.8.18 IDE would crash just after starting (opened all the windows, then crashed.) (Even more interesting: if I started the IDE from a terminal window (this is on MacOS Monterey; YMMV) to see why it was crashing, it would NOT crash, and apparently worked correctly.)
It wasn't worth messing with, and I ended up just copying over the sketchbook and reinstalling the boards from the board manager.
It did look like there might be incompatibilities in the preferences.txt file...
Things I don't like about IDE2:
  1. No portable mode.
  2. don't like the new (tiled) Serial Monitor.
  3. Can't specify the build directory.
My sketchbook folder contains my sketches but also my libraries, and one hardware addition (328P on a breadboard). Presumably all of that would transfer successfully. But it's good to know that the other stuff (added boards like ESP8266) might not. Not sure what to think might break in preferences.
Sorry to revisit this, but I can't figure out how to use the link provided by @ptillisch in post #4. What I'd like to know is what boards I would not have if I install IDE v1.8.19, but don't update the boards manager.
The TL;DR is that there is no reason to use the outdated version of the "Arduino AVR Boards" platform. Use Boards Manager to update to the latest version and move on with your Arduino projects.
The amount of hard drive space used by the extra copy of the platform is insignificant in the context of modern hard drive capacity.
It is purely informational. This is the repository where the source code of the "Arduino AVR Boards" platform is hosted.
There are a couple of ways you might "use" the link, including:
  • As an alternative to looking at the source code of the copy of the platform that is installed on your computer.
    ⓘ For your own personal purposes, it is best to look at the content of the actual files you are using. However, it is useful to be able to reference an online copy of the code when discussing it on the Internet.
  • As a convenient way to view the revision history of the project via the GitHub web interface.
  • In a git clone command to make a local clone of the repository in preparation to working with it using Git.
  • To view the existing bug reports and feature requests in the issue tracker, or submit a new one.
  • To contribute to the development of the project by submitting a pull request (PR)
You can determine this by doing a comparison of the contents of the platform's boards.txt file:
https://github.com/arduino/ArduinoCore-avr/compare/1.8.3..1.8.6#diff-c3a7c63d53cdec402cf559c1707ce5ef639a7e59e575f41ac5c8f5941e806a9f
diff --git a/boards.txt b/boards.txt
index 1344fbb..c100ecc 100644
--- a/boards.txt
+++ b/boards.txt
@@ -1,4 +1,4 @@
-# See: http://code.google.com/p/arduino/wiki/Platforms
+# See: https://arduino.github.io/arduino-cli/latest/platform-specification/
 menu.cpu=Processor
@@ -15,8 +15,19 @@ yun.vid.2=0x2A03
 yun.pid.2=0x0041
 yun.vid.3=0x2A03
 yun.pid.3=0x8041
+yun.upload_port.0.vid=0x2341
+yun.upload_port.0.pid=0x0041
+yun.upload_port.1.vid=0x2341
+yun.upload_port.1.pid=0x8041
+yun.upload_port.2.vid=0x2A03
+yun.upload_port.2.pid=0x0041
+yun.upload_port.3.vid=0x2A03
+yun.upload_port.3.pid=0x8041
+yun.upload_port.4.board=yun
 yun.upload.tool=avrdude
+yun.upload.tool.default=avrdude
+yun.upload.tool.network=arduino_ota
 yun.upload.protocol=avr109
 yun.upload.maximum_size=28672
 yun.upload.maximum_data_size=2560
@@ -26,6 +37,7 @@ yun.upload.use_1200bps_touch=true
 yun.upload.wait_for_upload_port=true
 yun.bootloader.tool=avrdude
+yun.bootloader.tool.default=avrdude
 yun.bootloader.low_fuses=0xff
 yun.bootloader.high_fuses=0xd8
 yun.bootloader.extended_fuses=0xfb
@@ -56,14 +68,30 @@ uno.vid.2=0x2A03
 uno.pid.2=0x0043
 uno.vid.3=0x2341
 uno.pid.3=0x0243
+uno.vid.4=0x2341
+uno.pid.4=0x006A
+uno.upload_port.0.vid=0x2341
+uno.upload_port.0.pid=0x0043
+uno.upload_port.1.vid=0x2341
+uno.upload_port.1.pid=0x0001
+uno.upload_port.2.vid=0x2A03
+uno.upload_port.2.pid=0x0043
+uno.upload_port.3.vid=0x2341
+uno.upload_port.3.pid=0x0243
+uno.upload_port.4.vid=0x2341
+uno.upload_port.4.pid=0x006A
+uno.upload_port.5.board=uno
 uno.upload.tool=avrdude
+uno.upload.tool.default=avrdude
+uno.upload.tool.network=arduino_ota
 uno.upload.protocol=arduino
 uno.upload.maximum_size=32256
 uno.upload.maximum_data_size=2048
 uno.upload.speed=115200
 uno.bootloader.tool=avrdude
+uno.bootloader.tool.default=avrdude
 uno.bootloader.low_fuses=0xFF
 uno.bootloader.high_fuses=0xDE
 uno.bootloader.extended_fuses=0xFD
@@ -79,12 +107,50 @@ uno.build.variant=standard
+unomini.name=Arduino Uno Mini
+unomini.vid.0=0x2341
+unomini.pid.0=0x0062
+unomini.upload_port.0.vid=0x2341
+unomini.upload_port.0.pid=0x0062
+unomini.upload_port.4.board=unomini
+unomini.upload.tool=avrdude
+unomini.upload.tool.default=avrdude
+unomini.upload.tool.network=arduino_ota
+unomini.upload.protocol=arduino
+unomini.upload.maximum_size=32256
+unomini.upload.maximum_data_size=2048
+unomini.upload.speed=115200
+unomini.bootloader.tool=avrdude
+unomini.bootloader.tool.default=avrdude
+unomini.bootloader.low_fuses=0xFF
+unomini.bootloader.high_fuses=0xDE
+unomini.bootloader.extended_fuses=0xFD
+unomini.bootloader.unlock_bits=0x3F
+unomini.bootloader.lock_bits=0x0F
+unomini.bootloader.file=optiboot/optiboot_atmega328.hex
+unomini.build.mcu=atmega328p
+unomini.build.f_cpu=16000000L
+unomini.build.board=AVR_UNO
+unomini.build.core=arduino
+unomini.build.variant=standard
 diecimila.name=Arduino Duemilanove or Diecimila
+diecimila.upload_port.0.board=diecimila
 diecimila.upload.tool=avrdude
+diecimila.upload.tool.default=avrdude
+diecimila.upload.tool.network=arduino_ota
 diecimila.upload.protocol=arduino
 diecimila.bootloader.tool=avrdude
+diecimila.bootloader.tool.default=avrdude
 diecimila.bootloader.low_fuses=0xFF
 diecimila.bootloader.unlock_bits=0x3F
 diecimila.bootloader.lock_bits=0x0F
@@ -126,10 +192,15 @@ diecimila.menu.cpu.atmega168.build.mcu=atmega168
 nano.name=Arduino Nano
+nano.upload_port.0.board=nano
 nano.upload.tool=avrdude
+nano.upload.tool.default=avrdude
+nano.upload.tool.network=arduino_ota
 nano.upload.protocol=arduino
 nano.bootloader.tool=avrdude
+nano.bootloader.tool.default=avrdude
 nano.bootloader.unlock_bits=0x3F
 nano.bootloader.lock_bits=0x0F
@@ -199,11 +270,27 @@ mega.vid.4=0x2341
 mega.pid.4=0x0210
 mega.vid.5=0x2341
 mega.pid.5=0x0242
+mega.upload_port.0.vid=0x2341
+mega.upload_port.0.pid=0x0010
+mega.upload_port.1.vid=0x2341
+mega.upload_port.1.pid=0x0042
+mega.upload_port.2.vid=0x2A03
+mega.upload_port.2.pid=0x0010
+mega.upload_port.3.vid=0x2A03
+mega.upload_port.3.pid=0x0042
+mega.upload_port.4.vid=0x2341
+mega.upload_port.4.pid=0x0210
+mega.upload_port.5.vid=0x2341
+mega.upload_port.5.pid=0x0242
+mega.upload_port.6.board=mega
 mega.upload.tool=avrdude
+mega.upload.tool.default=avrdude
+mega.upload.tool.network=arduino_ota
 mega.upload.maximum_data_size=8192
 mega.bootloader.tool=avrdude
+mega.bootloader.tool.default=avrdude
 mega.bootloader.low_fuses=0xFF
 mega.bootloader.unlock_bits=0x3F
 mega.bootloader.lock_bits=0x0F
@@ -256,14 +343,26 @@ megaADK.vid.2=0x2A03
 megaADK.pid.2=0x003f
 megaADK.vid.3=0x2A03
 megaADK.pid.3=0x0044
+megaADK.upload_port.0.vid=0x2341
+megaADK.upload_port.0.pid=0x003f
+megaADK.upload_port.1.vid=0x2341
+megaADK.upload_port.1.pid=0x0044
+megaADK.upload_port.2.vid=0x2A03
+megaADK.upload_port.2.pid=0x003f
+megaADK.upload_port.3.vid=0x2A03
+megaADK.upload_port.3.pid=0x0044
+megaADK.upload_port.4.board=megaADK
 megaADK.upload.tool=avrdude
+megaADK.upload.tool.default=avrdude
+megaADK.upload.tool.network=arduino_ota
 megaADK.upload.protocol=wiring
 megaADK.upload.maximum_size=253952
 megaADK.upload.maximum_data_size=8192
 megaADK.upload.speed=115200
 megaADK.bootloader.tool=avrdude
+megaADK.bootloader.tool.default=avrdude
 megaADK.bootloader.low_fuses=0xFF
 megaADK.bootloader.high_fuses=0xD8
 megaADK.bootloader.extended_fuses=0xFD
@@ -288,8 +387,19 @@ leonardo.vid.2=0x2A03
 leonardo.pid.2=0x0036
 leonardo.vid.3=0x2A03
 leonardo.pid.3=0x8036
+leonardo.upload_port.0.vid=0x2341
+leonardo.upload_port.0.pid=0x0036
+leonardo.upload_port.1.vid=0x2341
+leonardo.upload_port.1.pid=0x8036
+leonardo.upload_port.2.vid=0x2A03
+leonardo.upload_port.2.pid=0x0036
+leonardo.upload_port.3.vid=0x2A03
+leonardo.upload_port.3.pid=0x8036
+leonardo.upload_port.4.board=leonardo
 leonardo.upload.tool=avrdude
+leonardo.upload.tool.default=avrdude
+leonardo.upload.tool.network=arduino_ota
 leonardo.upload.protocol=avr109
 leonardo.upload.maximum_size=28672
 leonardo.upload.maximum_data_size=2560
@@ -299,6 +409,7 @@ leonardo.upload.use_1200bps_touch=true
 leonardo.upload.wait_for_upload_port=true
 leonardo.bootloader.tool=avrdude
+leonardo.bootloader.tool.default=avrdude
 leonardo.bootloader.low_fuses=0xff
 leonardo.bootloader.high_fuses=0xd8
 leonardo.bootloader.extended_fuses=0xcb
@@ -323,8 +434,15 @@ leonardoeth.vid.0=0x2a03
 leonardoeth.pid.0=0x0040
 leonardoeth.vid.1=0x2a03
 leonardoeth.pid.1=0x8040
+leonardoeth.upload_port.0.vid=0x2a03
+leonardoeth.upload_port.0.pid=0x0040
+leonardoeth.upload_port.1.vid=0x2a03
+leonardoeth.upload_port.1.pid=0x8040
+leonardoeth.upload_port.2.board=leonardoeth
 leonardoeth.upload.tool=avrdude
+leonardoeth.upload.tool.default=avrdude
+leonardoeth.upload.tool.network=arduino_ota
 leonardoeth.upload.protocol=avr109
 leonardoeth.upload.maximum_size=28672
 leonardoeth.upload.maximum_data_size=2560
@@ -334,6 +452,7 @@ leonardoeth.upload.use_1200bps_touch=true
 leonardoeth.upload.wait_for_upload_port=true
 leonardoeth.bootloader.tool=avrdude
+leonardoeth.bootloader.tool.default=avrdude
 leonardoeth.bootloader.low_fuses=0xff
 leonardoeth.bootloader.high_fuses=0xd8
 leonardoeth.bootloader.extended_fuses=0xcb
@@ -367,8 +486,23 @@ micro.vid.4=0x2341
 micro.pid.4=0x0237
 micro.vid.5=0x2341
 micro.pid.5=0x8237
+micro.upload_port.0.vid=0x2341
+micro.upload_port.0.pid=0x0037
+micro.upload_port.1.vid=0x2341
+micro.upload_port.1.pid=0x8037
+micro.upload_port.2.vid=0x2A03
+micro.upload_port.2.pid=0x0037
+micro.upload_port.3.vid=0x2A03
+micro.upload_port.3.pid=0x8037
+micro.upload_port.4.vid=0x2341
+micro.upload_port.4.pid=0x0237
+micro.upload_port.5.vid=0x2341
+micro.upload_port.5.pid=0x8237
+micro.upload_port.6.board=micro
 micro.upload.tool=avrdude
+micro.upload.tool.default=avrdude
+micro.upload.tool.network=arduino_ota
 micro.upload.protocol=avr109
 micro.upload.maximum_size=28672
 micro.upload.maximum_data_size=2560
@@ -378,6 +512,7 @@ micro.upload.use_1200bps_touch=true
 micro.upload.wait_for_upload_port=true
 micro.bootloader.tool=avrdude
+micro.bootloader.tool.default=avrdude
 micro.bootloader.low_fuses=0xff
 micro.bootloader.high_fuses=0xd8
 micro.bootloader.extended_fuses=0xcb
@@ -406,8 +541,19 @@ esplora.vid.2=0x2A03
 esplora.pid.2=0x003C
 esplora.vid.3=0x2A03
 esplora.pid.3=0x803C
+esplora.upload_port.0.vid=0x2341
+esplora.upload_port.0.pid=0x003C
+esplora.upload_port.1.vid=0x2341
+esplora.upload_port.1.pid=0x803C
+esplora.upload_port.2.vid=0x2A03
+esplora.upload_port.2.pid=0x003C
+esplora.upload_port.3.vid=0x2A03
+esplora.upload_port.3.pid=0x803C
+esplora.upload_port.4.board=esplora
 esplora.upload.tool=avrdude
+esplora.upload.tool.default=avrdude
+esplora.upload.tool.network=arduino_ota
 esplora.upload.protocol=avr109
 esplora.upload.maximum_size=28672
 esplora.upload.maximum_data_size=2560
@@ -417,6 +563,7 @@ esplora.upload.use_1200bps_touch=true
 esplora.upload.wait_for_upload_port=true
 esplora.bootloader.tool=avrdude
+esplora.bootloader.tool.default=avrdude
 esplora.bootloader.low_fuses=0xff
 esplora.bootloader.high_fuses=0xd8
 esplora.bootloader.extended_fuses=0xcb
@@ -438,10 +585,15 @@ esplora.build.extra_flags={build.usb_flags}
 mini.name=Arduino Mini
+mini.upload_port.0.board=mini
+mini.upload.tool.default=avrdude
+mini.upload.tool.network=arduino_ota
+mini.bootloader.tool.default=avrdude
 mini.bootloader.low_fuses=0xff
@@ -483,13 +635,18 @@ mini.menu.cpu.atmega168.build.mcu=atmega168
 ethernet.name=Arduino Ethernet
+ethernet.upload_port.0.board=ethernet
 ethernet.upload.tool=avrdude
+ethernet.upload.tool.default=avrdude
+ethernet.upload.tool.network=arduino_ota
 ethernet.upload.protocol=arduino
 ethernet.upload.maximum_size=32256
 ethernet.upload.maximum_data_size=2048
 ethernet.upload.speed=115200
 ethernet.bootloader.tool=avrdude
+ethernet.bootloader.tool.default=avrdude
 ethernet.bootloader.low_fuses=0xff
 ethernet.bootloader.high_fuses=0xde
 ethernet.bootloader.extended_fuses=0xFD
@@ -507,13 +664,18 @@ ethernet.build.core=arduino
 fio.name=Arduino Fio
+fio.upload_port.0.board=fio
 fio.upload.tool=avrdude
+fio.upload.tool.default=avrdude
+fio.upload.tool.network=arduino_ota
 fio.upload.protocol=arduino
 fio.upload.maximum_size=30720
 fio.upload.maximum_data_size=2048
 fio.upload.speed=57600
 fio.bootloader.tool=avrdude
+fio.bootloader.tool.default=avrdude
 fio.bootloader.low_fuses=0xFF
 fio.bootloader.high_fuses=0xDA
 fio.bootloader.extended_fuses=0xFD
@@ -531,12 +693,17 @@ fio.build.variant=eightanaloginputs
 bt.name=Arduino BT
+bt.upload_port.0.board=bt
 bt.upload.tool=avrdude
+bt.upload.tool.default=avrdude
+bt.upload.tool.network=arduino_ota
 bt.upload.protocol=arduino
 bt.upload.speed=19200
 bt.upload.disable_flushing=true
 bt.bootloader.tool=avrdude
+bt.bootloader.tool.default=avrdude
 bt.bootloader.low_fuses=0xff
 bt.bootloader.unlock_bits=0x3F
 bt.bootloader.lock_bits=0x0F
@@ -577,8 +744,15 @@ LilyPadUSB.vid.0=0x1B4F
 LilyPadUSB.pid.0=0x9207
 LilyPadUSB.vid.1=0x1B4F
 LilyPadUSB.pid.1=0x9208
+LilyPadUSB.upload_port.0.vid=0x1B4F
+LilyPadUSB.upload_port.0.pid=0x9207
+LilyPadUSB.upload_port.1.vid=0x1B4F
+LilyPadUSB.upload_port.1.pid=0x9208
+LilyPadUSB.upload_port.2.board=LilyPadUSB
 LilyPadUSB.upload.tool=avrdude
+LilyPadUSB.upload.tool.default=avrdude
+LilyPadUSB.upload.tool.network=arduino_ota
 LilyPadUSB.upload.protocol=avr109
 LilyPadUSB.upload.maximum_size=28672
 LilyPadUSB.upload.maximum_data_size=2560
@@ -588,6 +762,7 @@ LilyPadUSB.upload.use_1200bps_touch=true
 LilyPadUSB.upload.wait_for_upload_port=true
 LilyPadUSB.bootloader.tool=avrdude
+LilyPadUSB.bootloader.tool.default=avrdude
 LilyPadUSB.bootloader.low_fuses=0xff
 LilyPadUSB.bootloader.high_fuses=0xd8
 LilyPadUSB.bootloader.extended_fuses=0xce
@@ -609,10 +784,15 @@ LilyPadUSB.build.extra_flags={build.usb_flags}
 lilypad.name=LilyPad Arduino
+lilypad.upload_port.0.board=lilypad
 lilypad.upload.tool=avrdude
+lilypad.upload.tool.default=avrdude
+lilypad.upload.tool.network=arduino_ota
 lilypad.upload.protocol=arduino
 lilypad.bootloader.tool=avrdude
+lilypad.bootloader.tool.default=avrdude
 lilypad.bootloader.unlock_bits=0x3F
 lilypad.bootloader.lock_bits=0x0F
@@ -655,10 +835,15 @@ lilypad.menu.cpu.atmega168.build.mcu=atmega168
 pro.name=Arduino Pro or Pro Mini
+pro.upload_port.0.board=pro
 pro.upload.tool=avrdude
+pro.upload.tool.default=avrdude
+pro.upload.tool.network=arduino_ota
 pro.upload.protocol=arduino
 pro.bootloader.tool=avrdude
+pro.bootloader.tool.default=avrdude
 pro.bootloader.unlock_bits=0x3F
 pro.bootloader.lock_bits=0x0F
@@ -734,11 +919,16 @@ pro.menu.cpu.8MHzatmega168.build.f_cpu=8000000L
 atmegang.name=Arduino NG or older
+atmegang.upload_port.0.board=atmegang
 atmegang.upload.tool=avrdude
+atmegang.upload.tool.default=avrdude
+atmegang.upload.tool.network=arduino_ota
 atmegang.upload.protocol=arduino
 atmegang.upload.speed=19200
 atmegang.bootloader.tool=avrdude
+atmegang.bootloader.tool.default=avrdude
 atmegang.bootloader.unlock_bits=0x3F
 atmegang.bootloader.lock_bits=0x0F
@@ -787,8 +977,19 @@ robotControl.vid.2=0x2A03
 robotControl.pid.2=0x0038
 robotControl.vid.3=0x2A03
 robotControl.pid.3=0x8038
+robotControl.upload_port.0.vid=0x2341
+robotControl.upload_port.0.pid=0x0038
+robotControl.upload_port.1.vid=0x2341
+robotControl.upload_port.1.pid=0x8038
+robotControl.upload_port.2.vid=0x2A03
+robotControl.upload_port.2.pid=0x0038
+robotControl.upload_port.3.vid=0x2A03
+robotControl.upload_port.3.pid=0x8038
+robotControl.upload_port.4.board=robotControl
 robotControl.upload.tool=avrdude
+robotControl.upload.tool.default=avrdude
+robotControl.upload.tool.network=arduino_ota
 robotControl.upload.protocol=avr109
 robotControl.upload.maximum_size=28672
 robotControl.upload.maximum_data_size=2560
@@ -798,6 +999,7 @@ robotControl.upload.use_1200bps_touch=true
 robotControl.upload.wait_for_upload_port=true
 robotControl.bootloader.tool=avrdude
+robotControl.bootloader.tool.default=avrdude
 robotControl.bootloader.low_fuses=0xff
 robotControl.bootloader.high_fuses=0xd8
 robotControl.bootloader.extended_fuses=0xcb
@@ -826,8 +1028,19 @@ robotMotor.vid.2=0x2A03
 robotMotor.pid.2=0x0039
 robotMotor.vid.3=0x2A03
 robotMotor.pid.3=0x8039
+robotMotor.upload_port.0.vid=0x2341
+robotMotor.upload_port.0.pid=0x0039
+robotMotor.upload_port.1.vid=0x2341
+robotMotor.upload_port.1.pid=0x8039
+robotMotor.upload_port.2.vid=0x2A03
+robotMotor.upload_port.2.pid=0x0039
+robotMotor.upload_port.3.vid=0x2A03
+robotMotor.upload_port.3.pid=0x8039
+robotMotor.upload_port.4.board=robotMotor
 robotMotor.upload.tool=avrdude
+robotMotor.upload.tool.default=avrdude
+robotMotor.upload.tool.network=arduino_ota
 robotMotor.upload.protocol=avr109
 robotMotor.upload.maximum_size=28672
 robotMotor.upload.maximum_data_size=2560
@@ -837,6 +1050,7 @@ robotMotor.upload.use_1200bps_touch=true
 robotMotor.upload.wait_for_upload_port=true
 robotMotor.bootloader.tool=avrdude
+robotMotor.bootloader.tool.default=avrdude
 robotMotor.bootloader.low_fuses=0xff
 robotMotor.bootloader.high_fuses=0xd8
 robotMotor.bootloader.extended_fuses=0xcb
@@ -858,6 +1072,9 @@ robotMotor.build.extra_flags={build.usb_flags}
 gemma.vid.0=0x2341
 gemma.pid.0=0x0c9f
+gemma.upload_port.0.vid=0x2341
+gemma.upload_port.0.pid=0x0c9f
+gemma.upload_port.1.board=gemma
 gemma.name=Arduino Gemma
@@ -865,6 +1082,7 @@ gemma.bootloader.low_fuses=0xF1
 gemma.bootloader.high_fuses=0xD5
 gemma.bootloader.extended_fuses=0xFE
 gemma.bootloader.tool=avrdude
+gemma.bootloader.tool.default=avrdude
 gemma.bootloader.lock_bits=
 gemma.bootloader.unlock_bits=
 gemma.bootloader.file=gemma/gemma_v1.hex
@@ -876,6 +1094,8 @@ gemma.build.variant=gemma
 gemma.build.board=AVR_GEMMA
 gemma.upload.tool=avrdude
+gemma.upload.tool.default=avrdude
+gemma.upload.tool.network=arduino_ota
 gemma.upload.maximum_size=5310
@@ -889,6 +1109,7 @@ circuitplay32u4cat.bootloader.file=caterina/Caterina-Circuitplay32u4.hex
 circuitplay32u4cat.bootloader.unlock_bits=0x3F
 circuitplay32u4cat.bootloader.lock_bits=0x2F
 circuitplay32u4cat.bootloader.tool=avrdude
+circuitplay32u4cat.bootloader.tool.default=avrdude
 circuitplay32u4cat.build.mcu=atmega32u4
 circuitplay32u4cat.build.f_cpu=8000000L
 circuitplay32u4cat.build.vid=0x239A
@@ -906,8 +1127,13 @@ circuitplay32u4cat.upload.disable_flushing=true
 circuitplay32u4cat.upload.use_1200bps_touch=true
 circuitplay32u4cat.upload.wait_for_upload_port=true
 circuitplay32u4cat.upload.tool=avrdude
+circuitplay32u4cat.upload.tool.default=avrdude
+circuitplay32u4cat.upload.tool.network=arduino_ota
 circuitplay32u4cat.vid.0=0x239A
 circuitplay32u4cat.pid.0=0x8011
+circuitplay32u4cat.upload_port.0.vid=0x239A
+circuitplay32u4cat.upload_port.0.pid=0x8011
+circuitplay32u4cat.upload_port.1.board=circuitplay32u4cat
@@ -918,8 +1144,15 @@ yunmini.vid.0=0x2a03
 yunmini.pid.0=0x0050
 yunmini.vid.1=0x2a03
 yunmini.pid.1=0x8050
+yunmini.upload_port.0.vid=0x2a03
+yunmini.upload_port.0.pid=0x0050
+yunmini.upload_port.1.vid=0x2a03
+yunmini.upload_port.1.pid=0x8050
+yunmini.upload_port.2.board=yunmini
 yunmini.upload.tool=avrdude
+yunmini.upload.tool.default=avrdude
+yunmini.upload.tool.network=arduino_ota
 yunmini.upload.protocol=avr109
 yunmini.upload.maximum_size=28672
 yunmini.upload.maximum_data_size=2560
@@ -929,6 +1162,7 @@ yunmini.upload.use_1200bps_touch=true
 yunmini.upload.wait_for_upload_port=true
 yunmini.bootloader.tool=avrdude
+yunmini.bootloader.tool.default=avrdude
 yunmini.bootloader.low_fuses=0xff
 yunmini.bootloader.high_fuses=0xd8
 yunmini.bootloader.extended_fuses=0xfb
@@ -955,8 +1189,15 @@ chiwawa.vid.0=0x2a03
 chiwawa.pid.0=0x0056
 chiwawa.vid.1=0x2a03
 chiwawa.pid.1=0x8056
+chiwawa.upload_port.0.vid=0x2a03
+chiwawa.upload_port.0.pid=0x0056
+chiwawa.upload_port.1.vid=0x2a03
+chiwawa.upload_port.1.pid=0x8056
+chiwawa.upload_port.2.board=chiwawa
 chiwawa.upload.tool=avrdude
+chiwawa.upload.tool.default=avrdude
+chiwawa.upload.tool.network=arduino_ota
 chiwawa.upload.protocol=avr109
 chiwawa.upload.maximum_size=28672
 chiwawa.upload.maximum_data_size=2560
@@ -966,6 +1207,7 @@ chiwawa.upload.use_1200bps_touch=true
 chiwawa.upload.wait_for_upload_port=true
 chiwawa.bootloader.tool=avrdude
+chiwawa.bootloader.tool.default=avrdude
 chiwawa.bootloader.low_fuses=0xff
 chiwawa.bootloader.high_fuses=0xd8
 chiwawa.bootloader.extended_fuses=0xfb
@@ -992,8 +1234,15 @@ one.vid.0=0x2a03
 one.pid.0=0x0001
 one.vid.1=0x2a03
 one.pid.1=0x8001
+one.upload_port.0.vid=0x2a03
+one.upload_port.0.pid=0x0001
+one.upload_port.1.vid=0x2a03
+one.upload_port.1.pid=0x8001
+one.upload_port.2.board=one
 one.upload.tool=avrdude
+one.upload.tool.default=avrdude
+one.upload.tool.network=arduino_ota
 one.upload.protocol=avr109
 one.upload.maximum_size=28672
 one.upload.maximum_data_size=2560
@@ -1003,6 +1252,7 @@ one.upload.use_1200bps_touch=true
 one.upload.wait_for_upload_port=true
 one.bootloader.tool=avrdude
+one.bootloader.tool.default=avrdude
 one.bootloader.low_fuses=0xff
 one.bootloader.high_fuses=0xd8
 one.bootloader.extended_fuses=0xfb
@@ -1025,8 +1275,13 @@ one.build.extra_flags={build.usb_flags}
 unowifi.name=Arduino Uno WiFi
 unowifi.vid.0=0x2A03
 unowifi.pid.0=0x0057
+unowifi.upload_port.0.vid=0x2A03
+unowifi.upload_port.0.pid=0x0057
+unowifi.upload_port.1.board=unowifi
 unowifi.upload.tool=avrdude
+unowifi.upload.tool.default=avrdude
+unowifi.upload.tool.network=arduino_ota
 unowifi.upload.protocol=arduino
 unowifi.upload.maximum_size=32256
 unowifi.upload.maximum_data_size=2048
@@ -1038,6 +1293,7 @@ unowifi.upload.network.endpoint_reset=/log/reset
 unowifi.upload.network.port=80
 unowifi.bootloader.tool=avrdude
+unowifi.bootloader.tool.default=avrdude
 unowifi.bootloader.low_fuses=0xFF
 unowifi.bootloader.high_fuses=0xDE
 unowifi.bootloader.extended_fuses=0x05
@@ -1052,3 +1308,5 @@ unowifi.build.core=arduino
 unowifi.build.variant=standard
 unowifi.build.esp_ch_uart_br=19200
 unowifi.build.extra_flags=-DESP_CH_UART -DESP_CH_UART_BR={build.esp_ch_uart_br}
So the answer to your question is that you would be missing the Arduino UNO Mini board.
But it also looks like there are some changes to some older boards. So I guess it makes sense to do the update. Thanks very much.
