Hi @mikedb. If you select File > Preferences from the Arduino IDE menus (note that you can't do that while the "Boards Manager" dialog is open), do you see anything in the "Additional Boards Manager URLs" field? If so, please provide the full contents of the field in a reply here.
Another question: after the problem happens, when you close the "Boards Manager" dialog, do you see any text in the black output panel at the bottom of the Arduino IDE window?
The preferences are only saved to disk when you exit Arduino IDE 1.x. So if you changed the preference, hung Boards Manager, and then had to force shut down Arduino IDE, then it is expected that the change you made to the preferences won't be present the next time you start Arduino IDE.
Unlike Arduino IDE 1.x, 2.x does not trigger a download of the package index files when you open Boards Manager. It instead periodically downloads them when you start the IDE, and after you make a change to the "Additional Boards Manager URLs" preference.
Try this:
Press the Ctrl+Shift+P keyboard shortcut (Command+Shift+P for macOS users) to open the "Command Palette".
A menu will appear on the editor toolbar:
Select the "Arduino: Update Package Index" command from the menu. ⓘ You can scroll down through the list of commands to find it or type the name in the field.
This will force Arduino IDE to perform an immediate download of the package index files. Do the downloads succeed?
Regardless of what the instructions say, the fact is that the URL http://drazzy.com/package_drazzy.com_index.json redirects to the URL https://drazzy.com/package_drazzy.com_index.json:
So the most correct URL to use is the final one: https://drazzy.com/package_drazzy.com_index.json
My hypothesis was that the use of the incorrect URL might have been the cause of the problem. Since you found that the fault still occurs even after changing the URL, this invalidates my hypothesis, but it was worth a try.
I did use ide 2.xx this time but I don't see any downloads or any errors or anything changing or happening.
But there is no problem with ide 2.xx only 1.8.19 hangs.
EDIT.
I repeated the prosses with ide 2.xx and saw a "Downloading bla bla ...." something flash on and off the screen , so yes looks like the download works.
If you find Arduino IDE 2.x to meet your needs, the I would say absolutely yes. No development or maintenance has been done on Arduino IDE 1.x for years. During that time, a significant number of new features and fixes have been implemented in Arduino IDE 2.x, and this will continue.
It is true that a some community members feel that Arduino IDE 1.x is superior in some way to 2.x. However, this is either due to fairly subjective reasons (e.g., "I don't like Serial Monitor being integrated in the main IDE window"), niche use cases (e.g., "I need 'portable' mode"), or some rare and mysterious incompatibility with their system (e.g., "It takes 10 minutes to compile a simple sketch, even though it only takes 30 seconds using 1.x"). My opinion is that, even if admittedly not perfect, 2.x is easily at least equally as good overall when compared to 1.x (which also has a significant number of defects).
Indeed. Do you have the same URLs in your Arduino IDE 2.x preferences as you have in your 1.x preferences? Arduino IDE 2.x uses a different preferences store than 1.x, so the URLs you added via the 1.x preferences aren't automatically also used by 2.x.
Are you using Arduino IDE 1.x in "portable" mode? I ask because both 1.x and 2.x normally store the downloaded package index files in the same location, but when you have 1.x in portable mode, it will instead store the files under the portable subfolder of the Arduino IDE installation folder. That "portable" location may be more problematic because there are special security restrictions on the C:\Program Files (x86) folder which is a default installation location for Arduino IDE.
I'm glad the compiling is working, but that is not directly relevant to this discussion. The discussion is about Arduino IDE 1.x hanging when it attempts to download the package index files. If your "Additional Boards Manager URLs" preference is empty, then Arduino IDE only downloads the primary package index (https://downloads.arduino.cc/packages/package_index.json). So you are not doing an "apples to apples" comparison between the two IDEs because Arduino IDE 1.x is downloading different files than Arduino IDE 2.x is (due to the different configurations of the two IDEs).
It is true that, assuming you already have all the boards platforms you need installed, having those extra URLs in your preferences is not essential when using Arduino IDE 2.x. However, these URLs are necessary in order to get updates when new versions of the platforms are released. So if you don't add those URLs to the Arduino IDE 2.x preferences, then you will forever remain stuck on the versions of the platforms that are currently installed and thus miss out on any enhancements or bug fixes the platform developers make.
That is irrelevant. You put Arduino IDE 1.x into "portable mode" by creating a folder named portable inside the Arduino IDE 1.x installation folder. Look in the folder. If you see a folder there named portable, then Arduino IDE 1.x is in "portable mode". If you don't see a folder there named portable, then Arduino IDE 1.x is not in "portable mode" and it is using the same folder to store the downloaded files as Arduino IDE 2.x does.
