SENDER
#include <NewPing.h>
#include <SoftwareSerial.h>
#define SONAR_NUM 4 // Number of sensors.
#define MAX_DISTANCE 200 // Maximum distance (in cm) to ping.
NewPing sonar[SONAR_NUM] = { // Sensor object array.
NewPing(7, 6, MAX_DISTANCE), // Each sensor's trigger pin, echo pin, and max distance to ping.
NewPing(3, 2, MAX_DISTANCE),
NewPing(5, 4, MAX_DISTANCE),
NewPing(9, 8, MAX_DISTANCE)
#define SERIAL_RX 11
#define SERIAL_TX 10
SoftwareSerial mySerial(SERIAL_RX, SERIAL_TX);
Serial.println("SDM-T3 Arduino Sender");
//mySerial.begin(4800);
// if (Serial.available())
for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through each sensor and display results.
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
Serial.print(i);
Serial.print("=");
Serial.print(sonar[i].ping_cm());
Serial.print("cm ");
Receber
//#include <LiquidCrystal_I2C.h>
#include <Keypad.h>
#include <SPI.h>
#include <RFID.h>
#include <Servo.h>
#define SERIAL_RX 10
#define SERIAL_TX 11
#define LED_PIN 13
RFID rfid(10, 9); //PIN10 liga SDA. PIN 9 liga RST
unsigned char status;
unsigned char str[MAX_LEN]; //comprimento do numero de serie
String accesso [1] = {"1171281215114"}; //numero de serie que dá acesso ao parque
int accessGrantedSize = 1; //numero de numeros de serie que dão acesso ao parque
Servo lockServo;
int lockPos = 10; //Servo Motor posição fechada
int unlockPos = 90; //Servo Motor posição aberta
boolean locked = true;
Servo lockServoOut;
int lockPosOut = 10; //Servo Motor saida posição fechada
int unlockPosOut = 90; //Servo Motor saida posição aberta
boolean lockedOut = true;
int redLEDPin = 15;
int greenLEDPin = 16;
const byte ROWS = 4; //NUMERO DE LINHAS DO TECLADO
const byte COLS = 3; //NUMERO DE COLUNAS DO TECLADO
char keys[ROWS][COLS] = { //DECLARAÇÃO DOS NUMEROS, LETRAS E CARACTERES DO TECLADO
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'},
byte rowPins[ROWS] = {2, 3, 4, 5 }; // PINOS DE CONEXAO DAS LINHAS DO TECLADO
byte colPins[COLS] = {6, 7, 8}; //PINOS DE CONEXAO DAS COLUNAS DO TECLADO
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS);
int receber;
String mensagemrecebida;
//Define a velocidade tranferencia de dados por segundo
//Apresentar a mensagem no ecra
Serial.println("SDM-T3 Arduino Receiver");
//o que liga os dois arduinos
//mySerial.begin(9600);
//lcd.init;
//lcd.begin(16,2);
SPI.begin();
rfid.init();
pinMode(redLEDPin, OUTPUT);
pinMode(greenLEDPin, OUTPUT);
//pinMode(greenLedOutPin, OUTPUT);
delay(200);
digitalWrite(redLEDPin, HIGH);
delay(200);
digitalWrite(greenLEDPin, HIGH);
delay(200);
//digitalWrite(greenLedOutPin, HIGH);
delay(200);
digitalWrite(redLEDPin, LOW);
delay(200);
digitalWrite(greenLEDPin, LOW);
delay(200);
//digitalWrite(greenLedOutPin, LOW);
lockServo.attach(14);
lockServo.write(lockPos); //Servo passa para lock position
//Serial.println("Aproxime o cartão");
//Inicio de propgramação
if(Serial.available()){
receber = mySerial.read();
mensagemrecebida = int (receber);
char mensagem[mensagemrecebida.length() + 1];
mensagemrecebida.toCharArray(mensagem, mensagemrecebida.length() + 1);
Serial.println(mensagem);
if (rfid.findCard(PICC_REQIDL, str) == MI_OK){
// Serial.println("Só o cartão é aceite");
String temp = "";
if (rfid.anticoll(str) == MI_OK){
// Serial.print("O numnero do cartão é : ");
for (int i = 0; i < 4; i++){
temp = temp + (0x0F & (str[i] >> 4));
temp = temp + (0x0F & str[i]);
//Serial.println("isto e a puta da variavel ");
//Serial.println (temp);
checkAccess (temp); //Check if the identified tag is an allowed to open tag
rfid.selectTag(str); //Lock card to prevent a redundant read, removing the line will make the sketch read cards continually
rfid.halt();
void checkAccess(String temp){
boolean granted = false;
for (int i=0; i <= (accessGrantedSize-1); i++){
if(accesso[i] == temp){
//Serial.println("Seja bem vindo, introduza o pin");
granted = true;
if (locked == true){
String passe = "";
for (int x = 0; x < 4; x++){
char Key = keypad.waitForKey();
passe = passe + Key;
// Serial.println(Key);
//Serial.println(passe);
if(passe == "1234"){
//Serial.println("PIN CORRETO, PODE ENTRAR");
lockServo.write(unlockPos);
locked = false;
delay(200);
else{
//Serial.println("PIN INCORRETO");
else if (locked == false){
locked = true;
if (granted == false){
//Serial.println ("Acesso recusado");
delay(200);
