Bonjour, je travail actuelement sur un systeme de scan, notament utilisant RFID, pour cela j'ai trouvé le code suivant : mais j'ai ce mess erreur :(
code ;
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9          // Configurable, see typical pin layout above
#define SS_PIN          10         // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
	Serial.begin(9600);		// Initialize serial communications with the PC
	while (!Serial);		// Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
	SPI.begin();			// Init SPI bus
	mfrc522.PCD_Init();		// Init MFRC522
	delay(4);				// Optional delay. Some board do need more time after init to be ready, see Readme
	mfrc522.PCD_DumpVersionToSerial();	// Show details of PCD - MFRC522 Card Reader details
	Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
	// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
	if ( ! mfrc522.PICC_IsNewCardPresent()) {
		return;
	// Select one of the cards
	if ( ! mfrc522.PICC_ReadCardSerial()) {
		return;
	// Dump debug info about the card; PICC_HaltA() is automatically called
	mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
Mess erreur ;
In file included from C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/MFRC522.h:13:0,
from sketch_mar22c.ino:2:
C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/require_cpp11.h:9:2: error: #error "This library needs at least a C++11 compliant compiler, maybe compiler argument for C++11 support is missing or if you use Arduino IDE upgrade to version >=1.6.6"
In file included from sketch_mar22c.ino:2:0:
C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/MFRC522.h:81:9: error: 'constexpr' does not name a type
static constexpr byte FIFO_SIZE = 64; // The FIFO is 64 bytes.
C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/MFRC522.h:81:9: note: C++11 'constexpr' only available with -std=c++11 or -std=gnu++11
C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/MFRC522.h:83:9: error: 'constexpr' does not name a type
static constexpr uint8_t UNUSED_PIN = UINT8_MAX;
C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/MFRC522.h:83:9: note: C++11 'constexpr' only available with -std=c++11 or -std=gnu++11
C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/MFRC522.h:309:111: error: 'nullptr' was not declared in this scope
StatusCode PCD_TransceiveData(byte *sendData, byte sendLen, byte *backData, byte *backLen, byte *validBits = nullptr, byte rxAlign = 0, bool checkCRC = false);
C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/MFRC522.h:310:112: error: 'nullptr' was not declared in this scope
StatusCode PCD_CommunicateWithPICC(byte command, byte waitIRq, byte *sendData, byte sendLen, byte *backData = nullptr, byte *backLen = nullptr, byte *validBits = nullptr, byte rxAlign = 0, bool checkCRC = false);
C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/MFRC522.h:310:137: error: 'nullptr' was not declared in this scope
C:\electronique\arduino-1.7.8\Arduino\libraries\rfid-master\src/MFRC522.h:310:164: error: 'nullptr' was not declared in this scope
:warning:
Post mis dans la mauvaise section, on parle anglais dans les forums généraux. déplacé vers le forum francophone.
Merci de prendre en compte les recommandations listées dans Les bonnes pratiques du Forum Francophone
Salut
J'essaierais d'abord de mettre à jour l'IDE (1.8.19). 1.7.8 ça date un peu.
